How to wire up a SpinX1 to 5i20 / 7i37
13 Jan 2019 16:33 #124115 by MATZE-ATZE-SCH
How to wire up a SpinX1 to 5i20 / 7i37 was created by MATZE-ATZE-SCH
Hello.
Im new to the Linux Stuff an want to convert a manual Mill to CNC with the help of LinuxCNC and Mesa Cards.
Now im on the Point, where I need to control a VFD via LinuxCNC. I have a 5i20, a 7i37TA and a 7i33TA for the axis motion.
Also a SpinX1. It is possible, to connect the SpinX1 to the 7i37TA, to get the PWM, ENA and DIR Signal?
And if it is, how I would connect it?
Would like to use Out0 for PWM, Out2 for ENA and Out4 for the DIR Signal.
The 7i37 is on P3 on the 5i20.
Best regards,
Marcel
13 Jan 2019 19:35 #124131 by PCW
Replied by PCW on topic How to wire up a SpinX1 to 5i20 / 7i37
Unfortunately The 7I37 outputs are a bit too slow for the SPINX1
The SpinX1 would be better connected directly to the 5I20s I/O pins
If you use a SV12 configuration you could have
P2 7I33
P3 SPINX1 using 3 pins directly from 5I20
P4 7I37
14 Jan 2019 02:58 #124146 by MATZE-ATZE-SCH
Replied by MATZE-ATZE-SCH on topic How to wire up a SpinX1 to 5i20 / 7i37
Hello,
I have the SVST8_4 firmware on the 5i20.
Will this work, too?
And can I do the config with the wizard?
Or need I to change the files manuel?
Best regards
Marcel
14 Jan 2019 09:48 #124163 by PCW
I think you can hand edit the hal file and change the firmware name
and the num_pwmgens token. This should not change anything else in your setup.
Then you will need to setup the hal PWM initialization and net connections
for the PWM pins on P3 you wish to use for the SPINX1
14 Jan 2019 11:13 #124171 by MATZE-ATZE-SCH
Hello,
Ok, I changed the input and output pins in the .hal from P3 to P4. That works fine.
The num_pwmgens i change from 4 to 5.
Now, how do i setup the hal to get the pwm, enable and dir signal to P3?
Can you show me an example?
Best regards
Marcel
14 Jan 2019 11:19 #124172 by PCW
You should be able to just copy paste a motion axis set of PWM initialization and net connections (changing the PWM mode to 0) and scaling/spindle net connections as appropriate
15 Jan 2019 12:14 #124252 by MATZE-ATZE-SCH
Hello,
OK, I have wired up the SpinX1.
But I don get it to work...
This is the things, I added to my .hal:
Warning: Spoiler!
But I can not get it to run?
Best regards
Marcel
15 Jan 2019 12:34 #124254 by PCW
Umm you are setting up a software PWM which is not needed and will not work well
You really want to enable and setup the hardware PWMGen channel 4
(on P3 pins 15,19,23 = IO 31,33,35 = PWM, DIR,ENA )
If you post your existing hal and ini files and I can copy paste a bit back at you with pwm channel 4 support
15 Jan 2019 13:15 #124258 by MATZE-ATZE-SCH
Hello,
here is the .HAL:
Warning: Spoiler!
And here is my .INI
Warning: Spoiler!
Thank you for your help!
Best regards
Marcel
15 Jan 2019 14:45 #124265 by PCW
The Spinx1 would like PWM at about 5 KHz
setp hm2_5i20.0.pwmgen.pwm_frequency 5000
Ideal drive for 7I33TA is PDM
That means all axis PWMGens should be set to mode 3
setp hm2_5i20.0.pwmgen.00.output-type 3
setp hm2_5i20.0.pwmgen.01.output-type 3
setp hm2_5i20.0.pwmgen.02.output-type 3
setp hm2_5i20.0.pwmgen.03.output-type 3
Then set PWMGen 04 to PWM mode
setp hm2_5i20.0.pwmgen.04.output-type 1
net spindle-speed-cmd motion.spindle-speed-out => hm2_5i20.0.pwmgen.04.value
net spindle-on motion.spindle-on => hm2_5i20.0.pwmgen.04.enable
# Set the spindle's top speed in RPM
setp hm2_5i20.0.pwmgen.04.scale 3000
This is just a sketch of whats needed so don't expect it to be perfect...
Moderators: PCW, jmelson
Time to create page: 0.191 seconds
