servo drive
- jmelson
- Thank you received: 126
25 Jan 2019 02:33 #124786
by jmelson
5.9 KW would require 38 A at 156 V.
Jon
Replied by jmelson on topic servo drive
That works out to 1.5 KW, so the current must be the continuous rating, not the peak.156v 9.5A are the servos some are more than 4kw i think 4.9kw & 5.9kw.
Jon
- vre
- Thank you received: 17
25 Jan 2019 04:57 - 25 Jan 2019 04:58 #124792
by vre
Replied by vre on topic servo drive
Last edit: 25 Jan 2019 04:58 by vre.
- Thank you received: 4654
25 Jan 2019 10:10 #124798
Replied by andypugh on topic servo drive
gitter.im/rene-dev/stmbl?at=5c4a6df6746d4a677a084b11
Though there is one major problem, the current design of STMBL uses a power IC which is completely unavailable. IRAM256-2067A2 (must be A2)
Octopart says that they exist but I am not sure I believe it.
octopart.com/iram256-2067a2-infineon-658...jwA-Y1RrKoEmfOlCLkfw
- vre
25 Jan 2019 13:52 #124810
by vre
If you read the datasheet of iram256-2067a2
it says
Motor power range up to 1.5kW / 85~253 Vac
mouser.com/datasheet/2/196/iram256-2067a-1226764.pdf
it says
25 Jan 2019 14:01 #124812
Yes, hard to reconcile all the numbers, isn't it?
But The IRAM is rated 20A 300V, which is 6kVA. (and 30A peak current)
But it's all a bit academic at the moment.
One good thing about the STMBL is that they cost <€100 each.
it says
- bevins
- Thank you received: 338
25 Jan 2019 15:30 #124822
by bevins
Replied by bevins on topic servo drive
Cant you just find an equivalent even if the footprint is not the same I am sure an adaptor could be done so it could work, no?
25 Jan 2019 15:55 #124824
It is possible to use the "A" (rather than A2) mounted on the wrong side. But then it doesn't fit in the case.
It is less trouble to redesign the HV board for a new power module. It just hasn't been done.
- vre
25 Jan 2019 19:40 #124850
by vre
Next stmbl version will have separate power stage components(igbt)
that will be available/interchangable
The following user(s) said Thank You: silopolis
Time to create page: 0.316 seconds
