7i40 motor cable shield
  • billykid
  • billykid's Avatar Topic Author
  • Platinum Member
  • Platinum Member
26 Jan 2019 15:24 #124932 by billykid
7i40 motor cable shield was created by billykid
hi, today I have placed the cables of my cnc and now the x axis has some disturbances .. I put an external cat 5e cable and rework everything well.
I would like to know the correct connection of the motor cable shield on the 7i40hv.
the 5 volts have the negative pole to ground, motor power 30 volts is floating.
I think they should be connected on the 2 gnd clamp and with a short piece of cable to the other 7i40 and to the chassis?
Thanks in advance
Mauro
26 Jan 2019 16:13 #124939 by PCW
Replied by PCW on topic 7i40 motor cable shield
Depending on the cause of the interference you may be able to eliminate it by setting the encoder filter a bit slower
  • billykid
  • Platinum Member
  • Platinum Member
27 Jan 2019 03:03 - 27 Jan 2019 03:08 #124951 by billykid
Replied by billykid on topic 7i40 motor cable shield
Thanks Peter
filter is already set to true is there a way to set it differently? however I can make it work, it was to connect the shields of the motor cables as there are I did not want to leave them disconnected.
max encoder count rate is 320 khz.
Last edit: 27 Jan 2019 03:08 by billykid.
27 Jan 2019 07:52 #124967 by PCW
Yes, in addition to enabling the filter you can set the encoder sampling clock frequency
the input digital filter times are in units of this sampling clock
( 3 clocks to be recognized with filter off and 15 clocks to be recognized with filter on )
  • billykid
  • Platinum Member
  • Platinum Member
27 Jan 2019 08:19 #124969 by billykid
the filter is already activated at 15 then ..
filter 1 or true ..
  • billykid
  • Platinum Member
  • Platinum Member
28 Jan 2019 03:35 #125060 by billykid
sorry but the language does not help me.
I understood the behavior of filter true and false but it depends on the clock, in this case 5i23 pci 33mhz I think. I have to lower something but I do not understand where.
28 Jan 2019 07:13 #125069 by PCW
The pin will be something like
hm2_5i23.0.encoder.sample-frequency
The following user(s) said Thank You: billykid
Moderators: PCW, jmelson
Time to create page: 0.232 seconds
