7C80
- blazini36
- Thank you received: 167
01 Feb 2019 19:32 - 01 Feb 2019 20:52 #125514
by blazini36
7C80 was created by blazini36
Last edit: 01 Feb 2019 20:52 by blazini36.
- pl7i92
- Thank you received: 359
02 Feb 2019 08:38 #125539
by pl7i92
Replied by pl7i92 on topic 7C80
You may ask him Direct Live on the IRC chatroom
USE hexchat
connect to freenode
and /join #linuxcnc
USE hexchat
connect to freenode
and /join #linuxcnc
- alkabal
- Thank you received: 52
11 Feb 2020 16:42 #157105
by alkabal
Replied by alkabal on topic 7C80
Hi
I'm thinking about ordering RPI4 + Mesa 7c80 for retrofit a mini mill
Did you know if this is possible to output PWM for control spindle with DAC using regular output or step output ?
i know this board include a digital dedicated circuit but i like to know if i can use other output.
Br
Br
- Thank you received: 5337
11 Feb 2020 17:13 #157108
Replied by PCW on topic 7C80
The 7C80 has a built-in isolated analog spindle control circuit
so no external interface hardware is needed, but if you require
a PWM output, a step/dir output or expansion connector
output could be used with the right firmware. In addition
if you dont need very fast response, you can use one of
the isolated outputs as a slow PWM source
(PWM limited to servo thread update rate )
- alkabal
11 Feb 2020 20:55 #157110
by alkabal
For right firmware, i need to customize myself ? (source code available ?)
I ask this because i have also a mini lathe with machinekit and for this one i haven't enough free wire for dedicated spindle circuit like this board (really something like impossible to add new wire in a cleaner way for this lathe spindle)
But this is really a great include !!! i plan to use this built-in control for mini mill
The question is mostly because i think about sharing control panel for both machine (hobby use)
Thanks a lot for reply
12 Feb 2020 10:46 - 12 Feb 2020 10:47 #157192
For a spindle its usually better to use an isolated interface circuit and they tend to generat a lot of EMI. As I mentioned, you can use one of the 7C80s isolated outputs and a RC filter
to generate and variable analog voltage
I also will be adding some 7C80 firmware options to support common parallel port BOBs
(like the ubiquitous "5 AXIS MACH" BOB) The "5 AXIS MACH" BOB has a analog spindle output
Last edit: 12 Feb 2020 10:47 by PCW.
- alkabal
12 Feb 2020 13:46 #157210
by alkabal
Yes you are right i have a fully isolated DAC circuit in the spindle enclosure.
I only need a "good" PWM output so if i understand : the best is use step or dir output for unisolated spindle PWM.
Thanks, BR
Thanks, BR
14 Feb 2020 19:16 - 14 Feb 2020 19:17 #157394
I have added a support zip file for the 7C80 with 4 new bitfiles
7c80_5abobd.bit 7C80 + Ebay special "5 Axis BOB"
7c801p_5abobd.bit + Ebay special "5 Axis BOB" Stepgen 5 on 7C80 step pin replaced with PWM
7c80_7i85d.bit 7C80 + 7I85
7c80_7i89d.bit 7C80 + 7I89
Last edit: 14 Feb 2020 19:17 by PCW.
- alkabal
15 Feb 2020 15:11 #157488
by alkabal
Hi
I'm sorry but i'm new with mesa board so i need confirmation.
7c801p_5abobd.bit this one allow to use the onboard step/dir output 5 for allow to use PWM out from this pin.
This firmware is compatible with 5 axis mach bob but as an option and can be used without this bob if the additional pin is not used by config ?
Thanks for your work :
15 Feb 2020 15:24 #157489
Yes, 7c801p_5abobd.bit replaces STEP5 with PWM1 (DIR5 is just GPIO)
The BOB is not required.
Time to create page: 0.150 seconds
