Linux parallel port @1911 not found
02 Feb 2019 09:44 #125544 by mpvriens
Linux parallel port @1911 not found was created by mpvriens
challange to find my driver board
Used a pice PEX1P board with a mach3 interface board
with lspi -vv i find:
02:00.0 Parallel controller: Oxford Semiconductor Ltd Device c110 (prog-if 02 [ECP])
Subsystem: Oxford Semiconductor Ltd Device c110
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 18
Region 0: I/O ports at e010
Region 1: I/O ports at e000
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=55mA PME(D0-,D1+,D2+,D3hot+,D3cold+)
Have put : loadrt hal_parport cfg="0x378" into my hal file , but don't get a respond from an in ore output
02 Feb 2019 10:11 #125548 by PCW
Replied by PCW on topic Linux parallel port @1911 not found
You would need to have
loadrt hal_parport cfg="0xe000" or
or
loadrt hal_parport cfg="0xe010"
instead of
in your hal file
26 Oct 2020 00:19 #187274 by hoffeys
Replied by hoffeys on topic Linux parallel port @1911 not found
Thank you! I'll be back up there in the afternoon to give that a shot :) Can you explain why I would use those addresses and not 0x378?
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
26 Oct 2020 00:58 #187276 by BeagleBrainz
Replied by BeagleBrainz on topic Linux parallel port @1911 not found
Because they are the addresses being reported by lspci. Address 0x378 doesn't exist for that card.
26 Oct 2020 10:58 #187320 by jmelson
Replied by jmelson on topic Linux parallel port @1911 not found
0x378 is the traditional on-motherboard parallel port address. PCI cards are enumerated by an algorithm that has an available address space and maps all the PCI devices before making decisions on what address to put them at.
The address space starts at 0x1000, I think, but almost all systems seem to map PCI devices above 0xa000.
Jon
26 Oct 2020 11:02 - 26 Oct 2020 11:04 #187322 by Todd Zuercher
Replied by Todd Zuercher on topic Linux parallel port @1911 not found
The 0x378 address is the address normally used for a motherboard's built in parallel port. It would never be used for the address of an add in PCI card. (Even if the motherboard does not have a built in parallel port.)
(edit: Jon beat me to it.)
Last edit: 26 Oct 2020 11:04 by Todd Zuercher.
Moderators: PCW, jmelson
Time to create page: 0.095 seconds
