- Thank you received: 10
Choices for Controller/Breakout Boards
- Project_Hopeless
- Topic Author
I plan on running LinuxCNC on a PC and I have parallel and USB ports available.
USB will never work for actual machine control due to inherent latency problems.
There are also plenty of Mesa cards to choose from that work perfectly with Linuxcnc, and we use them to control industrial machines, but at a extremely low price for what they are capable of.
- Leon82
- Thank you received: 79
You can turn on a spindle, have estop and 3 inputs for limit switches. And 5 axes.
On messa electronic website click on Linux CNC compatible cards. There is an Ethernet version 7i76e I think. It has many many features
- Project_Hopeless
- Topic Author
But it is Ethernet. Will there be any latency issues? Anything special need to happen on the PC side to the NIC?
- Leon82
In mach 3 they use them(smooth stepper) a lot because I think windows can be a turd sometimes
- Thank you received: 5334
external hardware for high speed tasks like step generation and
encoder counting relaxes this requirement considerably compared
to parallel port configurations.
- Project_Hopeless
- Topic Author
Is that what the 7i96 board does?PCW wrote: LinuxCNC stll requires real time access to motion hardware but using
For example step generation is done by a "digital frequency generator"
so that instead of linuxCNC generating every step, LinuxCNC just sends
a new step _rate_ command every 1 ms, and reads the accumulated
step count (and fractional step count) for feedback
- Leon82
tommylight wrote: Or 7i96, much cheaper and plenty of features.
I just saw that one. I assumed that the e version was the only one.
They also have one that has a parallel port connector on it so you can use your existing breakout board if you want to upgrade to an Ethernet
