Mesa 7i43 (2port parallel) 400K with bitfile SVST2_4_7i47 using PnCConf
27 Feb 2019 16:17 #127257 by mane
i ordered a 7i43 card and want to use the pin file SVST2_4_7i47 because it fits best to my project.
Found some information here.
linuxcnc.org/docs/2.6/html/drivers/hostmot2.html
My system:
LinuxCNC/AXIS version 2.7.14
Linux linuxcnc 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
For testing purposes i used SVST4_4 to see if my card is working. And it is working.
In PnCConf is no SVST2_4_7i47 selectable. I downloaded 7i43.zip file from mesa.
Used the bit file "SVST2_4_7I47S.BIT" and copied it to /lib/firmware/hm2/7i43-4/
Copied the pin file "SVST2_4_7I47.PIN" to /usr/share/doc/hostmot2-firmware-7i43-4
But the file is not selectable in PnCConf.
Is this the right bit file (4Encoder/2PWM/4StepGen/24GIPO) as discribed in the documentation above?
And what do i have to do to make this file selectable in PnCConf?
Many thanks
Manfred
27 Feb 2019 16:32 #127259 by pl7i92
loading the 7i43 with a 7i47 Bitfile is not in general a good idee as it is not build for this
pncconf does not automatic get the Bit and Pinfile
PLEASE ask cmorney if he got it inside
it is under constand Development
you can also ask in the Live Chatroom on IRC
PCW will help you Calafornia Timezone
27 Feb 2019 16:47 #127264 by andypugh
The 7i47 is just a 50-pin daughter card. There is no reason that it wouldn't work perfectly well with the 7i43.
27 Feb 2019 18:22 - 27 Feb 2019 18:22 #127278 by PCW
I dont think pncconf supports that configuration but you can use pncconf to create a working
hal/ini file set for a similar configuration (say SVST4_4) and edit the hal file to make any 7I47 specific changes.
Note that since stepgens, pwmgens, and encoder hardware is accessed in hal by number, not pin, there is very little difference in configurations for different daughtercards that have have basic stepgens, encoders, pwmgens etc
Last edit: 27 Feb 2019 18:22 by PCW.
27 Feb 2019 20:33 - 27 Feb 2019 20:35 #127288 by mane
I don´t really understand, sorry.
Let´s say i use SVST4_4 configuration and use only 1Encoder, 1PWM, 4StepGen. Will this result in some GPIO?
Last edit: 27 Feb 2019 20:35 by mane. Reason: corretion done
27 Feb 2019 21:05 - 27 Feb 2019 21:07 #127294 by PCW
The hal setup for the stepgens and PWMs and encoders would be the same for any Mesa
FPGA card or firmware. The only difference would be any GPIO pins used as plain GPIO,
or inversion of PWM/Stepgen pins referenced by GPIO pin number (and the base FPGA card name)
That is if you just have 1 PWM generator, its always going to be referred to as PWM 0
in the hal file not by the pins its connected to.
Likewise, if you have 4 Stepgens, they will be accessed in hal as stepgen 0 to stepgen 3
Last edit: 27 Feb 2019 21:07 by PCW.
28 Feb 2019 20:06 #127352 by mane
Today i tried to make a very basic configuration with PnCConf.
Used SVST4_4 bitfile and created only 3 step generators. On the tabs for IO connector 3 and 4 i have now many unused inputs.
After starting my configuration i listed the pinout with
sudo mesaflash --device 7i43 --epp --addr 0x378 --readhmid
But the pins are not as expected. There are PWM, Encoder but no GIPO.
manfred@linuxcnc:~$ sudo mesaflash --device 7i43 --epp --addr 0x378 --readhmid
Configuration Name: HOSTMOT2
  BoardName : MESA7I43
  FPGA Size: 400 KGates
  FPGA Pins: 144
  Number of IO Ports: 2
  Width of one I/O port: 24
  Clock Low frequency: 50.0000 MHz
  Clock High frequency: 100.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  ClockFrequency: 50.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: IOPort
  There are 2 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: QCount
  There are 4 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: PWM
  There are 4 of PWM in configuration
  Version: 0
  Registers: 5
  BaseAddress: 4000
  ClockFrequency: 100.000 MHz
  Module: StepGen
  There are 4 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: AddrX
  There are 1 of AddrX in configuration
  Version: 0
  Registers: 4
  BaseAddress: 7800
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for P4
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       QCount           1        Quad-B          (In)
 3      1   IOPort       QCount           1        Quad-A          (In)
 5      2   IOPort       QCount           0        Quad-B          (In)
 7      3   IOPort       QCount           0        Quad-A          (In)
 9      4   IOPort       QCount           1        Quad-IDX        (In)
11      5   IOPort       QCount           0        Quad-IDX        (In)
13      6   IOPort       PWM              1        PWM             (Out)
15      7   IOPort       PWM              0        PWM             (Out)
17      8   IOPort       PWM              1        Dir             (Out)
19      9   IOPort       PWM              0        Dir             (Out)
21     10   IOPort       PWM              1        /Enable         (Out)
23     11   IOPort       PWM              0        /Enable         (Out)
25     12   IOPort       QCount           3        Quad-B          (In)
27     13   IOPort       QCount           3        Quad-A          (In)
29     14   IOPort       QCount           2        Quad-B          (In)
31     15   IOPort       QCount           2        Quad-A          (In)
33     16   IOPort       QCount           3        Quad-IDX        (In)
35     17   IOPort       QCount           2        Quad-IDX        (In)
37     18   IOPort       PWM              3        PWM             (Out)
39     19   IOPort       PWM              2        PWM             (Out)
41     20   IOPort       PWM              3        Dir             (Out)
43     21   IOPort       PWM              2        Dir             (Out)
45     22   IOPort       PWM              3        /Enable         (Out)
47     23   (unknown-gtag)     (unknown-gtag)     Global    Unknown         (Out)
IO Connections for P3
 1     24   IOPort       StepGen          0        Step/Table1     (Out)
 3     25   IOPort       StepGen          0        Dir/Table2      (Out)
 5     26   IOPort       StepGen          0        Table3          (Out)
 7     27   IOPort       StepGen          0        Table4          (Out)
 9     28   IOPort       StepGen          0        Table5          (Out)
11     29   IOPort       StepGen          0        Table6          (Out)
13     30   IOPort       StepGen          1        Step/Table1     (Out)
15     31   IOPort       StepGen          1        Dir/Table2      (Out)
17     32   IOPort       StepGen          1        Table3          (Out)
19     33   IOPort       StepGen          1        Table4          (Out)
21     34   IOPort       StepGen          1        Table5          (Out)
23     35   IOPort       StepGen          1        Table6          (Out)
25     36   IOPort       StepGen          2        Step/Table1     (Out)
27     37   IOPort       StepGen          2        Dir/Table2      (Out)
29     38   IOPort       StepGen          2        Table3          (Out)
31     39   IOPort       StepGen          2        Table4          (Out)
33     40   IOPort       StepGen          2        Table5          (Out)
35     41   IOPort       StepGen          2        Table6          (Out)
37     42   IOPort       StepGen          3        Step/Table1     (Out)
39     43   IOPort       StepGen          3        Dir/Table2      (Out)
41     44   IOPort       StepGen          3        Table3          (Out)
43     45   IOPort       StepGen          3        Table4          (Out)
45     46   (unknown-gtag)     (unknown-gtag)     Global    Unknown         (Out)
47     47   IOPort       StepGen          3        Table6          (Out)
File Name: 7i43.hal
File Size:10 KB
28 Feb 2019 20:15 - 28 Feb 2019 20:22 #127354 by PCW
That's expected, notice the first column ( Pri. func ) in mesaflashes pin list? ( IOPort )
All pins are available as GPIO if they are not claimed by an _enabled_ secondary function (Sec. func)
Edit
Also you should not run mesaflash when LinuxCNC is running ( notice the bad data on GPIO23?, this is likely due to a access collision )
To check available hardware pins, run
halcmd show pin hm2*
or
for gpio:
halcmd show pin *gpio*
Last edit: 28 Feb 2019 20:22 by PCW.
28 Feb 2019 20:24 #127356 by andypugh
Mesaflash lists the firmware pinout, not the pinout that is active in your configuration.
If you start LinuxCNC from the command line you should get the actual pinout that your config is using listed on the screen.
01 Mar 2019 16:44 #127439 by mane
Tried to start from command line, but nothing listed on the screen.
manfred@linuxcnc:~/linuxcnc/configs/7i43$ linuxcnc 7i43.ini
LINUXCNC - 2.7.14
Machine configuration directory is '/home/manfred/linuxcnc/configs/7i43'
Machine configuration file is '7i43.ini'
Running HAL shutdown script
Starting LinuxCNC...
Found file(REL): ./7i43.hal
Found file(REL): ./custom.hal
Moderators: PCW, jmelson
Time to create page: 1.354 seconds
