'error finishing read' with 7i80/7i90 combo
30 Mar 2019 23:47 #130007 by cmorley
I have a 7i80 ->7i44->7i90
->stmbl
using just HAL session (linuxcnc master), I can run the cards with seemingly no problem but, I get the error:
'hm2/hm2_7i80.0: error finishing read! iter=1365116'
if I set an output on the 7i90 with:
setp hm2_7i80.0.7i90.0.0.p3-out-23 true
Any idea what that could be - any other info you need?
Chris M
31 Mar 2019 02:01 - 31 Mar 2019 02:02 #130008 by tommylight
Replied by tommylight on topic 'error finishing read' with 7i80/7i90 combo
First check the servo thread in the ini file, just in case.
What does that output activate ? Anything with induction like relay, motor, transformer, etc ?
In case any of the above, check the wiring for proper grounding, check cables for shielding, and so on.
Hope it helps.
Also if you have a DVM check the voltage for drops when activating that output.
Last edit: 31 Mar 2019 02:02 by tommylight.
31 Mar 2019 02:24 #130009 by PCW
Yeah, "error finishing read" usually means you have lost all contact with the
FPGA card (7I80 in this case) possibly caused by a complete power failure or
FPGA card reset.
31 Mar 2019 03:33 #130013 by cmorley
Replied by cmorley on topic 'error finishing read' with 7i80/7i90 combo
Thank you - that lead me to the temporary power supply not having enough current for the optos to be turned on when setting outputs.
Chris
31 Mar 2019 06:47 #130017 by pl7i92
Replied by pl7i92 on topic 'error finishing read' with 7i80/7i90 combo
@pcw
Sir woudent it be Good to adress this in the Documentation of the MESA stuff
as so many try them out first and run in Issues / errors they woudt never see on Mashine side
with full power
as i did also face this with my 7i92 test
01 Apr 2019 02:47 #130064 by cmorley
So to just finish this ...
I originally had 5 volt power to the 7i80 and 7i44 - i had missed the 7i90.
If I set an output on the 7i90 it would kill the sserial service.
Then I added 5volt power to the 7i90 and could set an output.
but i couldn't set two outputs....
Finally after setting the single output on the 7i90 then measuring the supply voltage on the 7i80 - it was down to ~4.20v (~4.9 without the output on)
I added a higher current supply to the 7i80 and that has seemed to fixed the problem.
I did seem counter-intuitive that the 7i90's outputs would effect the 7i80's supply voltage... considering there is a powered 7i44 between then.
Chris M
Moderators: PCW, jmelson
Time to create page: 0.193 seconds
