7i76e was working, now CR1 LED does not go off
7 years 7 months ago #130100 by PCW
I dont think CR1 is meaningful in this case
I would check the individual signals to the step drives
7 years 6 months ago #130232 by macla
I downloaded the .bit file PCW included a link to and executed the following command:
sudo mesaflash --device 7i76e --addr 192.168.1.121 --fallback write 7i76e_7i76x1D.bit
and got this reply: "ETH device 7I76E-16 at ip=192.168.1.121".
Not what I expected?
7 years 6 months ago - 7 years 6 months ago #130234 by PCW
Its what I would expect...
Why are you attempting to write the fallback configuration?
( This should really never need to be done and you don't want to
write a standard config to the fallback area either )
If you want to update the firmware, the command would be:
mesaflash --device 7i76e --write 7i76e_7i76x1D.bit
then a power cycle or
mesaflash --device 7i76e --reload
Last edit: 7 years 6 months ago by PCW.
7 years 6 months ago #130236 by macla
Because I clearly didn't understood when to use the fallback region and therefore followed the guide I linked to earlier - This guide said "When we try to flash a new bitfile onto the board we first try it in the fallback region. Let's flash the new 5i25_7i76_7i85s.bit bitfile and try if it works." This is apparently NOT the way to do it.
Anyway - it worked! The board now initializes correctly and CR1 goes off when I start up Linuxcnc.
Thanx alot!
Moderators: PCW, jmelson
Time to create page: 0.298 seconds
