How to check a Mesa 7i76e if it is defective.
07 Apr 2019 06:33 #130424 by Edi_48
Hello
I got my Mesa 7i76E early March directly from Mesashop.
I can't get the iHSV57-36 stepper to work.
When I enter data into Linuxcnc 2.8, the pointer goes in the desired direction but
The motors don't move. My Hal and Ini were adapted from the Talla83.
If I measure the outputs X,Y,Z from the map I get the following result.
X Dir + and Dir- 0 Volt and with Step + and Step- also 0 Volt
Y Dir + and Dir- 0,25 Volt and at Step + and Step- 5 Volt
The motors go with a rotary encoder .
Is now my card defect
Hilton
08 Apr 2019 00:21 #130461 by rodw
Did you happen to connect 5V to the enable pins on the stepper driver? If you did, remove it as its stepper disable signal.
08 Apr 2019 01:20 - 08 Apr 2019 01:21 #130470 by PCW
If Step+ and Step- ( or Dir+ and Dir-) are at the same voltage (and they are not shorted externally) This means the output drivers have been damaged, one should always be the opposite of the other ( if +StepN or +DirN is 5V -StepN or -DirN must be 0V and vice versa)
Note that you cannot measure the pins on the green connectors via the screws
on the top of the connectors unless the screws are tight.
Last edit: 08 Apr 2019 01:21 by PCW.
08 Apr 2019 05:37 #130478 by Edi_48
A cable has been connected to measure
How do I get returns approval to return the card?
08 Apr 2019 13:40 #130511 by PCW
Did you measure _between_ the + and - step/dir pins with a voltmeter?
If the result of this measurement is not ~5V or ~-5V when LinuxCNC is idle
then the output drivers have been damaged somehow. If this is the case you can request a RMA number at sales.mesanet.com
09 Apr 2019 16:44 #130562 by PCW
Note, I tried to reply to your email to Mesa but it bounced, do you have an email address that works?
02 May 2019 19:28 #132560 by PCW
Received your 7I76E card
No problems were found, all I/O including step/dir outputs are OK
I suspect you have a pinout or wiring error of some kind
Moderators: PCW, jmelson
Time to create page: 0.187 seconds
