7i92 7i49
- MaxEkb77
- Thank you received: 9
26 Apr 2019 08:45 #131934
by MaxEkb77
7i92 7i49 was created by MaxEkb77
Hello.
I have question, can i connect 7i49 via 7i92 card ?
Thank you.
Thank you.
- AnnoyingMutt
- Visitor
26 Apr 2019 13:12 #131949
by AnnoyingMutt
Replied by AnnoyingMutt on topic 7i92 7i49
I'll take a guess as to no.
With 7i92 being of the DB25 variety card and the 7i49 being of the 50 pin variety.
I'd guess these would be the cards to mate with the 7i49
store.mesanet.com/index.php?route=produc...69_62&product_id=324
store.mesanet.com/index.php?route=produc...=69_62&product_id=62
- Thank you received: 4654
26 Apr 2019 16:06 #131979
Physically, yes. Using either a home-made cable or store.mesanet.com/index.php?route=produc...74_80&product_id=285 but it might not work.
However the 7i49 needs more IO pins than the 7i92 has, so even with a compatible firmware you would lose some functionality.
The 7i93 would be a better bet.
store.mesanet.com/index.php?route=produc...83_85&product_id=324
What is your application?
Replied by andypugh on topic 7i92 7i49
Hello.
I have question, can i connect 7i49 via 7i92 card ?.
- pl7i92
- Thank you received: 358
26 Apr 2019 16:39 #131994
by pl7i92
Replied by pl7i92 on topic 7i92 7i49
the 7i92 is mainly for upgrating PARPORT systems to ETH
the 7i93 is for the "old" mesa fpga stuff 50pin to get to the ETH benefits
- Thank you received: 5326
26 Apr 2019 17:09 #132002
Replied by PCW on topic 7i92 7i49
As AnnoyingMutt & Andy have said, a 7I80HD or 7I93 are the best bet.
It might make some kind of sense if you already had a 7I92 and didn't mind making a custom cable.
You would need to get by with 17 vs 23 pins (assuming you did not want to steal from the second 7I92 connector)
its possible to do this by sacrificing 3 analog outs (6 pins) Whether this is a good compromise or not is up to you.
- MaxEkb77
27 Apr 2019 04:23 #132060
by MaxEkb77
Replied by MaxEkb77 on topic 7i92 7i49
Sorry to short question.
I have old 4 axis cnc machine, on machine installed resolver on motor and linear resolver.
How I can receive a position to linuxcnc ?
I have 7i49 and 7i92 now, 7i49 in pdf connect via spi interface, I read pdf 7i92 he can support Spi interface. I check firmwares to 7i92 don’t see Spi pins.
If 7i49 can work with my resolver, I buy additional card. If not I move to optical position feedback system.
Sorry write from phone.
Thank you for your answers.
27 Apr 2019 05:06 - 27 Apr 2019 05:07 #132061
As mentioned before you would be better off with a 50 pin FPGA card for use with the 7I49.
The SPI interface is hidden in the resolver firmware on the FPGA card so you
just need firmware that supports the resolver interface ( usually has RM in the bitfile
name like "7i80hd_16_rmsvss6_8.bit" )
What type of resolvers do you have? It would be good to verify that they will work
with the 7I49 before going further in that direction.
Last edit: 27 Apr 2019 05:07 by PCW.
03 May 2019 00:38 #132583
The 7i49 definitely works, and works well. Both my mill and my lathe rely on the 7i49 for position feedback.
The following user(s) said Thank You: MaxEkb77
- MaxEkb77
22 Aug 2019 18:14 - 22 Aug 2019 18:15 #142867
by MaxEkb77
Thank you, I order 7i93 & 7i37ta
In manual text talk about firmware for 7i49 I download bit files from Mesa site & don’t see this firmware maybe anybody have compiled bit file ?
Last edit: 22 Aug 2019 18:15 by MaxEkb77.
22 Aug 2019 18:30 #142870
Time to create page: 0.263 seconds
