Retrofit of Precix 5x10 CNC
7 years 5 months ago #132651 by Todd Zuercher
That "black box" that is the control unit isn't a computer, though it likely contains one.
Everything is packed into it, control computer, power-supply, and servo drives. But it still going to be comprised of individual components.
Your job as a retro-fitter, is to determine what you can and can't reuse.
Who knows, you may even be able to reuse the original PC motherboard. If it is suitable for Linuxcnc. I doubt the original PC to servo interface card(s) will be will be supported with Linuxcnc, but likely everything else could be reused. If you can identify what they are so that manuals describing how they are used can be dug up.
7 years 5 months ago - 7 years 5 months ago #132652 by PCW
Replied by PCW on topic Retrofit of Precix 5x10 CNC
Yeah, I think I see three drives, one with a black anodized heatsink and 2 with gold Alodine heatsinks
on the last of the photo of the large photo series.
Last edit: 7 years 5 months ago by PCW. Reason: heatsink color
7 years 5 months ago - 7 years 5 months ago #132654 by bevins
Replied by bevins on topic Retrofit of Precix 5x10 CNC
You could become friends with these guys....
precixpartswarehouse.com/parts-service
and wefixprecix.com/ , this guy is a member here. He worked where this machine was built. He would probably be able to steer you in the right direction.
member: linuxcnc forum member, wefixprecix
Last edit: 7 years 5 months ago by bevins.
7 years 5 months ago #132655 by randypetersen
Thanks for your input Todd, really appreciate it!
I know I gotta get those drives out so I can get a model number for you guys and check for compatibility.
It's be nice if I could reuse them, but if not, I can understand. It'd be nice to keep the motors, but it's kinda nice to have newer things just so you can get replacements.
I suppose, if I end up changing everything out, I might be able to change to steppers then I would have to buy a new breakout board.
Would you recommend sticking with servos? The guy I bought the machine from was singing their praises vs steppers, but I don't have any experience with them to be honest.
Thanks again Todd.
7 years 5 months ago #132657 by randypetersen
Thanks bevins, I will shoot them a message!
I like your idea about the replacement of the motors too. If I went with those I would need the 7i77? or the step/dir controller?
Ya, they put everything in that box... computer/cpuPSU/drivePSU/drives... pretty crowded. So I am going to take cpu stuff out and then just have a stand alone computer. Ethernet wire or db25 connecting them. Should give it some space.
7 years 5 months ago #132659 by randypetersen
Thanks PCW!
I will get some more information on those items.
If you guys were retrofitting the machine, would you update the drives/motors at the same time?
Moderators: PCW, jmelson
Time to create page: 0.273 seconds
