7i76e What's Preferred Source or Sinking Field I/O
- Project_Hopeless
- Thank you received: 10
05 May 2019 17:33 #132862
by Project_Hopeless
7i76e What's Preferred Source or Sinking Field I/O was created by Project_Hopeless
For a build from scratch hobby machine I plan to start off with mechanical travel switches but may upgrade to proximity sensor latter on.
Is there any advantage to one card over the other (7i76E/7i76ED)?
What size 24v power supply do you typically need assuming proximity switches for limits, 24v relay?
- Thank you received: 5326
05 May 2019 17:51 - 05 May 2019 17:52 #132866
Replied by PCW on topic 7i76e What's Preferred Source or Sinking Field I/O
If you are building from scratch, I think the 7I76E version is a better choice.
If you are retrofitting a machine that has relays pre-wired for a sinking driver
then a 7I76ED makes more sense.
Sourcing outputs have the advantage that a wiring short to ground will not enable an output.
Sinking outputs have the advantage that you can mix output voltage levels.
If you are only driving relays and proximity switches, 24V @ 1A should be plenty
If 11 inputs and 6 outputs will do and you don't need the analog spindle interface,
a 7I96 is another choice.
It has uncommitted outputs that can be sinking or sourcing on a per output basis.
Last edit: 05 May 2019 17:52 by PCW.
- Project_Hopeless
05 May 2019 18:56 #132868
by Project_Hopeless
Replied by Project_Hopeless on topic 7i76e What's Preferred Source or Sinking Field I/O
7i96e is actually my prefered choice. But I keep going back and forth 96e vs. 76e as I try and plan the simplest way to to configure power supply(s) for the board and switches.If 11 inputs and 6 outputs will do and you don't need the analog spindle interface,
