Total I/O from a 7i96 + 7i73?
- Ross77
30 May 2019 20:17 #135420
by Ross77
Total I/O from a 7i96 + 7i73? was created by Ross77
What would the total I/O capacity be a 7i96 and a 7i73 (including the expansion port) ?
I wouldn't use a key board on the 7i73 just sensor inputs or relay outputs.
- Thank you received: 5326
30 May 2019 20:45 #135423
Replied by PCW on topic Total I/O from a 7i96 + 7i73?
well...
11 isolated inputs on 7I96 + 6 high current outputs,17 TTL level I/O on 7I96 parallel expansion connector + 24 inputs and 22 outputs on 7I73
so 76 I/O total (not including the step/dir outputs)
Note that a 7I73 is not the best general purpose I/O card since it has a mix of 3.3V and 5V tolerant I/O
A 7I90HD (with sserial remote firmware) would give you 72x 5V tolerant inputs/outputs (sinking outputs)
- Ross77
30 May 2019 22:26 #135432
by Ross77
Replied by Ross77 on topic Total I/O from a 7i96 + 7i73?
Thanks, I mainly wanted to check that there was plenty of spare capacity.
The 7i96 is favourite at the moment because of the step/ dir, isolated I/O and everything on 3.5mm terminals. It would cost quite a bit more to add the cards to the 7i90HD to get the same level of protection and easy connections (unless I'm misunderstanding how the 7i90HD can be used?)
Can the mpg inputs on the 7i73 be used for axis encoder feedback?
30 May 2019 22:38 #135433
I think you mis-understood, a 7I90HD can be used a Sserial I/O expander
Like the 7I73 but with more digital I/O (though GPIO only)
MPG encoders are not really suitable for axis encoders unless they are low resolution
- Ross77
30 May 2019 23:17 #135437
by Ross77
Sorry, my mistake I was looking at the 7i80HD
7i90HD makes more sense. Can it accept highspeed encoders and analog inputs like the 7i73?
is it fully supported and compatible with 7i96?
30 May 2019 23:33 #135438
No high speed encoders with the current firmware, though its possible
The 7I90 has no analog I/O but does have 72 5V tolerant digital I/O
- Ross77
31 May 2019 17:16 #135489
by Ross77
Will there be firmware for the encoders soon?
How many of the 7i73 I/o are 5v tolerant?
It looks like I would have a good spread of digital and analogue I/O with the 7i96 and the 7i73. should cover most options
- HueyHQ
- Thank you received: 24
31 May 2019 21:11 #135502
by HueyHQ
Replied by HueyHQ on topic Total I/O from a 7i96 + 7i73?
I'm interested in that, too!How many of the 7i73 I/o are 5v tolerant?
- Clive S
- Thank you received: 486
31 May 2019 21:53 #135503
by Clive S
From the manual:-
INPUT CHARACTERISTICS
All inputs are LVTTL compatible (3.3V input maximum) except inputs 8 through 15.
Inputs 8 through 15 are 5V tolerant. Inputs 8 through 15 are also available as encoder
inputs. Inputs 8 through 15 have 4.7 K pull-up resistors so will read high when
unconnected. Inputs 0 through 7 are available as analog inputs. Inputs 0 through 7 have
no pull-up or pull-down resistors so present a minimal load on analog signals. If inputs 0
through 7 are used for switch sensing, external pull-up or pull-down resistors must be
added. The analog reference voltage is brought out on J2 pins 11 and 12 for ratiometric
measurement applications (like potentiometers). When keypad inputs are available as
input bits, they have 10K pull-ups, so will read high when unconnected.
Replied by Clive S on topic Total I/O from a 7i96 + 7i73?
From the manual:-
- Ross77
01 Jun 2019 10:24 #135555
by Ross77
So of the 24 inputs:
8 analogue inputs - pins 0-7 (3.3v, can be used for switching but needs pull up res)
8 digital inputs - pins 8-15 ( 5v tolerant, 4x mpg/encoder inputs)
8 digital inputs ( 3.3v tolerant, keyboard inputs)
Am I right in thinking that the 3.3v inputs could be used for cycle start/ stop etc and free up the main I/O on the 7i96?
Time to create page: 1.944 seconds
