7i96 hm2: firmware contains unknown function gtag-195
- danilom
- Thank you received: 5
05 Jun 2019 12:10 #135933
by danilom
7i96 hm2: firmware contains unknown function gtag-195 was created by danilom
Using Stretch image from download with PREEMPT RT and with Linuxcnc 2.7.14
On startup I get message
hm2: firmware contains unknown function (gtag-195)
Anyone knows anything about this?
- Thank you received: 5326
05 Jun 2019 12:56 #135934
Replied by PCW on topic 7i96 hm2: firmware contains unknown function gtag-195
Yes, the 7I96 requires LinuxCNC 2.8 for support of the SSR (isolated output) modules
- danilom
05 Jun 2019 16:07 #135952
by danilom
Replied by danilom on topic 7i96 hm2: firmware contains unknown function gtag-195
Thanks , I just tried master and installed 2.9 so not getting that warning any more, Did not try the outputs yet.
What I am getting now is that somehow output step velocity has too much jitter. The motors stutter . This is stepper system and P is 1000 FF1 is 1 . I constantly have some following error and its going back and forth like untuned servo. It seems it has nothing with 7i96 but its from PID output or input
05 Jun 2019 16:09 #135953
Can you post your hal/ini files? sounds like a setup error of some kind
- danilom
05 Jun 2019 16:16 #135955
by danilom
No problem here they are
05 Jun 2019 16:26 #135957
A couple of things
1.
addf hm2_[HOSTMOT2](BOARD).0.write servo-thread
should be the last addf (after the PID calculations)
2.
all lines like
setp pid.n.maxerror .0005
should be changed to
setp pid.n.maxerror .013
(or just commented out)
3. all lines like
net n-vel-cmd => pid.n.command-deriv
should be commented out
1.
2.
all lines like
3. all lines like
- danilom
05 Jun 2019 17:12 #135962
by danilom
That seems to have fixed it !
Thanks Peter
Thanks Peter
Time to create page: 0.300 seconds
