7i96E pwmgen Type not Found
- Project_Hopeless
- Thank you received: 10
12 Jun 2019 23:47 #136796
by Project_Hopeless
7i96E pwmgen Type not Found was created by Project_Hopeless
I have my PC and 7i96 card talking. I setup the ini file with the 7i96 Tool, set to 5 step-gen matching the cards firmware.
When I load LinuxCNC with my ini file it crashes I believe it is crashing on a missing pwm setting.
All drives are stepper motors, spindle=0 so no pwm required. What could it be?
Debug file information:
Note: Using POSIX realtime
iptables: No chain/target/match by that name.
./homecnc_02.hal:169: parameter or pin 'hm2_7i96.0.pwmgen.00.output-type' not found
1605
Stopping realtime threads
Unloading hal componentsAll drives are stepper motors, spindle=0 so no pwm required. What could it be?
- persei8
- Thank you received: 133
13 Jun 2019 00:13 #136798
by persei8
Replied by persei8 on topic 7i96E pwmgen Type not Found
For some reason, the 7i96 config tool sets the pwm type to 0 regardless of what you tell it. In your homecnc_02.hal file, find the section starting with :
# Spindle
and replace
setp hm2_7i96.0.pwmgen.00.output-type 0
with
setp hm2_7i96.0.pwmgen.00.output-type 1
Should work.
# Spindle
and replace
with
Should work.
- Thank you received: 5323
13 Jun 2019 00:45 - 13 Jun 2019 00:45 #136803
Replied by PCW on topic 7i96E pwmgen Type not Found
Looks like possible a bug in the configuration utility
(if you did not specify any spindle output features)
I would just comment out the following lines in the hal file:
setp hm2_7i96.0.pwmgen.00.scale [SPINDLE]MAX_RPM
setp hm2_7i96.0.pwmgen.pwm_frequency [SPINDLE]PWM_FREQUENCY
Last edit: 13 Jun 2019 00:45 by PCW.
- Project_Hopeless
14 Jun 2019 12:25 #136874
by Project_Hopeless
Replied by Project_Hopeless on topic 7i96E pwmgen Type not Found
That is what I had to do. Just changing the type didn't seem to work.I would just comment out the following lines in the hal file:
14 Jun 2019 12:33 #136875
The standard 7I96 firmware doesn't have a PWM generator so any reference
to one will be an error.
- persei8
14 Jun 2019 14:34 #136881
by persei8
I missed that the OP said 5 stepgens. That one has no PWM. My board has 4 stepgens and PWM so changing the 0 to a 1 fixed the error.
Time to create page: 0.111 seconds
