7i76e smoke issues
- AlessandroT
- Thank you received: 4
19 Jun 2019 00:52 #137257
by AlessandroT
7i76e smoke issues was created by AlessandroT
Hi folks, while I was trying to figure it out how to talk with the board, the square spartan component located nearby the ethernet started to smoke. Everything was very very hot.
It was only connected to the eth cable and the 5v power Inn, so I was surprised.
I wasn't able to ping the board, so now I don't know if it's broken or not. There is a method to check the board? I installed the stretch linux version from here: www.linuxcnc.org/testing-stretch-rtpreempt/ ---> linuxcnc-stretch-uspace-amd64.iso.
Is it ok this version with the 7i76e board?
Thank you in advance
- Online
- Thank you received: 5326
19 Jun 2019 01:36 #137259
Replied by PCW on topic 7i76e smoke issues
If the FPGA overheated, it is likely gone. I would check you 5V supply very carefully
before using it again.
For initial testing its best to use a current limited supply (a USB power cord works well for this)
- AlessandroT
19 Jun 2019 02:16 #137263
by AlessandroT
Replied by AlessandroT on topic 7i76e smoke issues
Thank you for the reply. Do you think that is possible to repair it or I need a new one? I see the led yellow and red on.
- Online
19 Jun 2019 03:34 #137265
Probably not repairable but we will issue a RMA to repair/replace the card
if you contact Mesa
if you contact Mesa
- Thank you received: 4654
20 Jun 2019 13:36 #137379
Replied by andypugh on topic 7i76e smoke issues
Is this something that could happen if the card is jumpered for cable power and has external 5V connected?
- Online
20 Jun 2019 13:49 - 20 Jun 2019 13:49 #137380
This is a 7I76E where the built in FPGA overheated and only power and Ethernet were connected. This suggests a power supply issue. It could be a random failure though I have never seen this type of failure before. (FPGA failures are most often caused by connecting voltages outside the safe area to I/O pins)
I do not trust unloaded ATX power supplies 5V rail so that could be an issue or it could be a problem with one of the on card switching regulators that supply 3.3V and 1.2V to the FPGA (from 5V)
Last edit: 20 Jun 2019 13:49 by PCW.
Time to create page: 0.292 seconds
