Rotary Delta Robot 4 axis
6 years 10 months ago - 6 years 10 months ago #152537 by barisduzenli
Yes, I saw in page 58, as you mentioned GND is Delta's pin 44. But in page 40 it is "13" too. Even I will change pin "13" to "44".
Last edit: 6 years 10 months ago by barisduzenli.
6 years 10 months ago #152550 by bevins
Replied by bevins on topic Rotary Delta Robot 4 axis
barisduzenli wrote: Yes, I saw in page 58, as you mentioned GND is Delta's pin 44. But in page 40 it is "13" too. Even I will change pin "13" to "44".
You can also disconnect the wire for +-10v velocity control and use a 1.5 volt battery connected to the +-10 input of the drive, and that should tell you which side the problem is.
If it doesnt move then it is not Lcnc side unless the drive is not enabled.
The following user(s) said Thank You: barisduzenli
6 years 10 months ago #152552 by barisduzenli
tommylight wrote: mesaflash --device 5i25 --readhmid
What does it return?
How is the 5V side on the 7i77 powered ?
I did not change jumper settings. But I am not sure Mesa 5i25's 5V is enough for my configuration.
Tomorrow I will try what returns mesaflash --device 5i25 --readmid command.
Thank you your fast answers.
6 years 10 months ago #152553 by bevins
If you want to supply external 5V, (I always do), then you have to change a jumper on the 5i25 and 7i77.
6 years 10 months ago #152591 by barisduzenli
Hello bevins, I tried to drive servos with a 1.5 battery. And, it works. I am checking wiring. And I will try to measure drive outputs of 7i77.
6 years 10 months ago #152592 by barisduzenli
Which jumpers I have to change on 5i25 and 7i77 ? I am just aware of W5 of 7i77. And nothing I found about 5i25.
Moderators: PCW, jmelson
Time to create page: 0.225 seconds
