Rotary Delta Robot 4 axis
6 years 10 months ago #152525 by bevins
Replied by bevins on topic Rotary Delta Robot 4 axis
Are you sure your drives re in velocity speed mode? Alot of drives come default as step/dir.
The following user(s) said Thank You: barisduzenli
6 years 10 months ago #152526 by bevins
You pins and inputs working? Hal configuration menu item. You can check your pins and ignals live.
If linuxcnc starts, dont worry about the LEDs on the card.
6 years 10 months ago #152527 by barisduzenli
Yes I changed P01-01 to "02" P02-15...P02-17 to"00" to disable limitswitch errors. And P02-30 to "01" to Servo On.
6 years 10 months ago #152528 by tommylight
mesaflash --device 5i25 --readhmid
What does it return?
How is the 5V side on the 7i77 powered ?
The following user(s) said Thank You: barisduzenli, slckzbn
6 years 10 months ago #152529 by bevins
I looked at the manual and it looks like your not connected to analog ref gnd should be pin 44. .
7i77 aout => pin 42 delta servo
7i77 gnd => pin 44 delta servo analog input signal gnd
You have it connected to 13
Also you can try with battery.
6 years 10 months ago #152530 by bevins
tommylight wrote: mesaflash --device 5i25 --readhmid
His pictures show he is getting 5v from 5i25
Moderators: PCW, jmelson
Time to create page: 0.065 seconds
