My machine has been working great for four years.
I am putting together a ,new, complete replacement spare computer.
The computer and Mesa 5i25 are new. Everything else is unchanged.
I decided to take the opportunity to update from 2.5 ubuntu to 2.7 debian 9 stretch.
I had to change several things in the ini and hal files.
I got it so that linuxcnc will start without error but the servo motors have very little torque and I get a following error immediately when I try to move an axis. If i set the following error to a very large number, the axis will move but is extremely weak.
the 8i20.0.0 current will go up to about 4.3 when I turn the motor pulley by hand.(before it errors)
This is about 30 times higher amperage than what I observe when hooked up to the old computer.
the 8i20 bus-voltage looks good at 166 volts
