Step-Direction vs Analog Command vs CW/CCW Signals
- bevins
- Thank you received: 338
13 Sep 2019 00:40 #145008
by bevins
Replied by bevins on topic Step-Direction vs Analog Command vs CW/CCW Signals
You become really good friends with HalScope whilst tuning........
- thefabricator03
- Visitor
13 Sep 2019 00:59 #145009
by thefabricator03
Replied by thefabricator03 on topic Step-Direction vs Analog Command vs CW/CCW Signals
Thanks bevins,
I guess at that price point you cant be picky, I have similar pricing for other china brand servos, I will see what I negotiate with them.
- bevins
13 Sep 2019 01:03 - 13 Sep 2019 01:07 #145010
by bevins
We could run it at 2100 inches per minute. I think that was 800 ipm or something like that in the video.
It is loud because of the rack and pinion.
We had a 10:1 planetary gearbox on the two Y motors and the X motor. THe Z just has a brake.
Thanks bevins,
Last edit: 13 Sep 2019 01:07 by bevins.
The following user(s) said Thank You: rodw, thefabricator03
- Thank you received: 4138
13 Sep 2019 03:31 #145025
And it seems a very coarse straight rack at that. I used one straight rack on X and 2 helical on the Y and I will never use a noisy straight rack again!
Replied by rodw on topic Step-Direction vs Analog Command vs CW/CCW Signals
Just a good Microphone!It is loud because of the rack and pinion.
- Thank you received: 7462
13 Sep 2019 09:55 #145041
There are several success stories around, and from what i read the only tricky part is getting the kinematics right, meaning the angles, lengths, and how they interact with each other.
CAM might be a bigger issue.
Replied by tommylight on topic Step-Direction vs Analog Command vs CW/CCW Signals
I would not thing to much about it, just do it.
9 Axis, much more joints, i think, in version 2.8 and 2.9 of Linuxcnc .
Yeah thats right 9 axises, and each axis can be comprised of multiple joints.
Tom, What are your thoughts on a 6 axis robot retrofit with Linuxcnc? For this robot there really is no other option. It was made in 1991 and the ERC contoller is very much antiquated.
- thefabricator03
- Visitor
13 Sep 2019 10:04 - 13 Sep 2019 10:04 #145042
by thefabricator03
Na I have CAM sorted,
Between Big Johns Teach-in.py script and this robodk.com/index
Last edit: 13 Sep 2019 10:04 by thefabricator03.
13 Sep 2019 11:19 #145049
Nice.
Nice.
- JR1050
- Thank you received: 31
17 Oct 2019 18:56 #148140
by JR1050
Replied by JR1050 on topic Step-Direction vs Analog Command vs CW/CCW Signals
There are different types of Yaskawa encoders, Id pull the manual up for the motor, see what was offered and see what you have. In my experience, even the older absolute encoders still used A A/ B B/ and a marker channel and still read incremental , they kept track of where they were with battery backed memory and reported to the controller serially. Yaskawa got out of the control business 17 years ago, my guess is you can re use them. The drives may or may not be analog, there was another post about the AC drives on an I80 control using pwm signals.
- thefabricator03
- Visitor
27 Jan 2020 14:33 - 27 Jan 2020 14:38 #155910
by thefabricator03
Andy,
Do you have anymore information about the STMBL drives and when they will be released?
Also do you think they will ever get Ethercat capabilities? And is there a better place to get info on them then the Gitter page? It really is a pain.
Are you in a hurry? If you can put this on hold for a few months there should be a new version of the STMBL drive out. That connects direct to Yaskawa servos with absolute encoders.
That should be a neat conversion with no loss of function.
Andy,
Last edit: 27 Jan 2020 14:38 by thefabricator03.
- Thank you received: 4648
27 Jan 2020 20:00 - 27 Jan 2020 20:00 #155943
Replied by andypugh on topic Step-Direction vs Analog Command vs CW/CCW Signals
I have heard that the (probably) final iteration of the new power stage is being tested.
Also someone on the STMBL Gitter chat is looking to make a batch of boards using a lower-power and still available version of the IRAMs chip.
But I am not deeply embedded in the project, so know no more than anyone else.
Last edit: 27 Jan 2020 20:00 by andypugh.
Time to create page: 0.198 seconds
