Firmware for 7I93
- brecked
10 Sep 2019 17:48 - 10 Sep 2019 17:49 #144724
by brecked
Firmware for 7I93 was created by brecked
Hi!
Please help with firmware for 7I93 mesa board setup:
7I93
connected to
7I49 and 7I44 connected to
6pc 8I20 , 7I70 and 7I71
Any sugestions is welcomed, its my first Mesa experience.
7I93
connected to
Last edit: 10 Sep 2019 17:49 by brecked.
- Thank you received: 5326
10 Sep 2019 19:33 #144734
Replied by PCW on topic Firmware for 7I93
The following user(s) said Thank You: brecked
- brecked
11 Sep 2019 05:37 #144780
by brecked
Replied by brecked on topic Firmware for 7I93
Thanks a lot! Is it all I need for this setup?
- Thank you received: 4654
17 Sep 2019 12:54 #145386
Replied by andypugh on topic Firmware for 7I93
You need to flash that bitfile with Mesaflash, and your INI / HAL config will be something that PnCConf probably can't help much with.
I have a couple of similar configs using 7i44 + 7i49 so should be able to help.
Here is an example to study, from my lathe.
Note the the config can be very simple if the resolver is aligned to the motor and has the same number of poles, (The Z axis) and in that case you can connect resolver.angle directly to 8i20.angle.
Things are rather less simple on the X axis, which is an 8 pole motor and single-pole resolver, and this requires the bldc component to recalculate the angle. The scale is always the same for any 7i49, but the offset will need to be found by experiment / guesswork. If the motor runs at the same speed in both directions it is a good sign that the offset is right, or close enough. It will be a number between 0 and +/- the scale.
- brecked
17 Sep 2019 13:40 #145390
by brecked
Super! Thanks for examples.
- brecked
25 Nov 2019 08:55 #151200
by brecked
Hi again!
At last I got to this project!
But I got a problem, what type of linuxcnc I should install to work with 7I93 card?
I found an instruction here :
forum.linuxcnc.org/9-installing-linuxcnc...iest-install?start=0
and here:
linuxcnc.org/docs/html/getting-started/g...th_preempt_rt_kernel
but terminal commands doesnt work. Is some other version of linuxcnc for these ethernet cards, or some other repository for packages ?
and here:
- Thank you received: 7478
25 Nov 2019 10:53 #151206
Replied by tommylight on topic Firmware for 7I93
Linuxcnc.org main page there is a download button, get the second, stretch version of the iso.
- brecked
25 Nov 2019 11:14 #151209
by brecked
Seems I got it working. Needed to use other apt-get repository found from here:
wiki.debian.org/DebianWheezy
deb archive.debian.org/debian wheezy main
- brecked
25 Nov 2019 12:07 - 25 Nov 2019 12:09 #151212
by brecked
Thanks Tommy ! Installed Strech instead.
Just got litle repeat of linux knowledge
Last edit: 25 Nov 2019 12:09 by brecked.
Time to create page: 0.416 seconds
