What is FPGA in Mesa.boards
- Dinuka_Shehan
- Thank you received: 26
13 Sep 2019 01:29 #145014
by Dinuka_Shehan
What is FPGA in Mesa.boards was created by Dinuka_Shehan
What is FPGA in mesa boards and IO pins.
What are the uses of them.
I cannot find clear meaning of them.
- bevins
- Thank you received: 338
13 Sep 2019 02:13 #145021
by bevins
FPGA wiki
Replied by bevins on topic What is FPGA in Mesa.boards
FPGA wiki
The following user(s) said Thank You: Dinuka_Shehan
- pl7i92
- Thank you received: 358
13 Sep 2019 06:53 #145027
by pl7i92
Replied by pl7i92 on topic What is FPGA in Mesa.boards
mesa uses spatan Chips
FPGA is a gate array that is user programable
so you can design your pwm your i/O direction and combinate them to timers
in Linuxcnc they are used for "HARDWARE" Stepgens that is not times by the PC
benefit is you send not individuell commands to eatch pin insted of cumminicate high speed >4M bit with the Fpga and let this do the timing
so you reatch a near 10times higher accoracy and speed on servo system
- Dinuka_Shehan
13 Sep 2019 19:18 #145076
by Dinuka_Shehan
Replied by Dinuka_Shehan on topic What is FPGA in Mesa.boards
Like 100000 latency value computer run with mesa board will give reasonable latency value
- Thank you received: 4151
14 Sep 2019 03:00 #145103
Yes, that will work
Replied by rodw on topic What is FPGA in Mesa.boards
Yes, that will work
Time to create page: 0.137 seconds
