7i96 Power
- phillc54
- Thank you received: 2100
22 Sep 2019 02:26 #145813
by phillc54
7i96 Power was created by phillc54
I am using a 7i96 in a plasma cutter.
I am thinking of mounting a THCAD-10 in the plasma cutter and powering it from a 24V-5V buck converter also mounted in the plasma cutter with the 24V sourced from the field power supply.
I assume this would mean tying the 0V rail of the 5v logic power supply to the 0V rail of the field power supply.
Is this likely to cause any problems or would I be better served powering the THCAD directly from the 5V logic power supply. Probably around 2-3 metres from the control panel to the plasma cutter.
- Thank you received: 5326
22 Sep 2019 02:33 #145815
Replied by PCW on topic 7i96 Power
I suspect its better to use 5V from the 7I96's encoder pins, say using CAT5 cable
but in any case a twisted pair for the frequency out.
- islander261
- Thank you received: 216
22 Sep 2019 19:27 #145885
by islander261
Replied by islander261 on topic 7i96 Power
Phill
I am using a locally mounted buck converter to power my THCad board. Mine is mounted in a screened box near the plasma power supply. So far it has worked fine.
- Thank you received: 4149
23 Sep 2019 09:45 #145939
Replied by rodw on topic 7i96 Power
I think I'm with PCW with this one. I had a 5.0m cable and while I put my THCAD in the control box, I did a lot of testing with divided voltage in the 3-6 volt range and never saw any appreciable voltage loss across that cable.
- pl7i92
- Thank you received: 358
23 Sep 2019 14:30 #145964
by pl7i92
Replied by pl7i92 on topic 7i96 Power
isent a robot industrial double shielded cat6 cable better to go for a thc its not that expensive against a standard cat5
i feld more secure on the use of this cable on my proma
- Thank you received: 7478
23 Sep 2019 15:00 #145969
Replied by tommylight on topic 7i96 Power
What config are you using with the Proma THC ?i feld more secure on the use of this cable on my proma
Time to create page: 0.222 seconds
