7i80hd-25 bitfile with uart
- sneci
29 Sep 2019 11:02 #146551
by sneci
7i80hd-25 bitfile with uart was created by sneci
Every bitfile that has uart, loaded fails with the following message:
"hm2/hm2_7i80.0: inconsistent Module Descriptor for UART Transmit Channel, not loading driver"
7i80 firmware is: 7i80hd_25_svua8_4.bit
Test file:
loadrt trivkins
loadrt motmod servo_period_nsec=1000000
loadrt hostmot2
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=2"
Test by halrun:
ls@pcb:~/linuxcnc/configs/ppgep$ halrun utest.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 192.168.1.121: Hardware address: 00:60:1b:11:80:09
hm2_eth: discovered 7I80HD-25
hm2/hm2_7i80.0: Version = 0, expected 0
hm2/hm2_7i80.0: NumRegisters = 4, expected 4
hm2/hm2_7i80.0: InstanceStride = 0x00000040, expected 0x00000010
hm2/hm2_7i80.0: MultipleRegisters = 0x0000000F, expected 0x0000000F
hm2/hm2_7i80.0: inconsistent Module Descriptor!
hm2/hm2_7i80.0: failed to parse Module Descriptor 4
board fails HM2 registration
hm2_eth: rtapi_app_main: Invalid argument (-22)
utest.hal:4: waitpid failed /home/ls/linuxcnc-dev/bin/rtapi_app hm2_eth
utest.hal:4: /home/ls/linuxcnc-dev/bin/rtapi_app exited without becoming ready
utest.hal:4: insmod for hm2_eth failed, returned -1
hm2: unloading
What might be the problem? Does the uart only work with an existing daughter card?
Sneci
Test file:
loadrt trivkins
loadrt hostmot2
Test by halrun:
hm2: unloading
Sneci
- pl7i92
- Thank you received: 358
29 Sep 2019 14:05 #146568
by pl7i92
Replied by pl7i92 on topic 7i80hd-25 bitfile with uart
hi what dautercard is connected
and is it correct powerd
- sneci
29 Sep 2019 14:19 #146572
by sneci
Replied by sneci on topic 7i80hd-25 bitfile with uart
hi,
I want a simple RS232 interface that communicates with my own hardware (ATXmega).
Sneci
Sneci
- pl7i92
29 Sep 2019 14:22 #146573
by pl7i92
you shoudt use a USB-rs232 extension and workout your own comp to get what you want out and in to the system
like most use for Hyanyang VFD
there is a component that uses this
also the XHC component uses Rs232 connection
- Thank you received: 5326
29 Sep 2019 14:51 #146581
Replied by PCW on topic 7i80hd-25 bitfile with uart
What configuration do you need?
If you are using 7I80 configuration from the zip file they are pretty old and may have bugs
- sneci
29 Sep 2019 14:56 #146583
by sneci
Thanks for the tip. it would be nice to handle communication in real time. Maybe there will be a solution
- sneci
29 Sep 2019 15:02 - 29 Sep 2019 15:03 #146587
by sneci
Hi Peter,
8 stepgens, 4 encoders, 1 pwm and simple uart rx-tx without protocol signals.
Last edit: 29 Sep 2019 15:03 by sneci.
29 Sep 2019 15:53 #146594
7I80HD-25 with 4 PWMs,4 Encoders, 12 stepgens and 4 UARTs
I have included the pinout source file in case you want some modifications
- sneci
29 Sep 2019 16:11 #146596
by sneci
Great, thank you.
I'll try and report on the result.
- Thank you received: 4654
03 Oct 2019 00:54 #146926
Replied by andypugh on topic 7i80hd-25 bitfile with uart
Note that there is a UART bug in the LinuxCNC driver
forum.linuxcnc.org/27-driver-boards/3711...nc2-8?start=0#141396
I will push the fix in the next few days. It isn't new n 2.8, but might have managed to work with a single UART despite the bug depending on the details of the compilation......
Time to create page: 0.293 seconds
