7i29 via ethernet?
7 years 3 weeks ago #147192 by snoozer77
7i29 via ethernet? was created by snoozer77
Hi Guys,
Might be a silly question, but just wondering if it would be possible to run a smart serial board from a 7i44 (or my pc ethernet port) to drive 2 x 7i29's?
Was using original servo drives, so my control pc is quite a distance away from my machine electrical cabinet. Now want to use 7i29's in same location as original drives, but dont know the best way to wire the drives over the 2 or so meter distance.
Any suggestions would be great.
Thank Matt
7 years 3 weeks ago #147199 by PCW
Replied by PCW on topic 7i29 via ethernet?
Yes, you could use a 7I93 Ethernet card to drive up to 4 7I29s
Sserial would theoretically be possible with a 7I90 but that's more of a firmware project
7 years 3 weeks ago #147240 by snoozer77
Replied by snoozer77 on topic 7i29 via ethernet?
Thank you, that sounds great.
The 7i93 doesnt seem to be listed in the store.mesanet.com. ??
Also wondering if there is any benifit in running a PCI based 5i24 over the ethernet 7i80HD ??
Thanks Matt
7 years 3 weeks ago #147295 by PCW
Sorry for some reason the 7I93 was disabled in the store (fixed)
Ethernet advantages:
isolation of all signals
simple cabling
PCI advantages
Somewhat simpler setup
Supports higher servo thread rates than Ethernet
The following user(s) said Thank You: tivoi
7 years 3 weeks ago #147432 by snoozer77
Thanks Peter.
Will have to pop through an order. :)
6 years 8 months ago #157697 by snoozer77
Hi PWC
Have been playing with the 7i80 and 7i93 that i purchased, cant seem to find a bitfile to match the same as the 5i24_25_rmsvss6_8_8.bit file i have for the 5i24. would it be possible to have a 7i80_16 bitfile made for my 7i49, 7i29 and 7i44. Also, sorry to be a pain, would it be possible to make a 7i49 and 7i29 bitfile for the 7i93 please.
Thanks for the support
Matt
Moderators: PCW, jmelson
Time to create page: 0.063 seconds
