- Hardware & Machines
- Driver Boards
- Does anyone have a link to a good tutorial on flashing a Mesa card 7i96e and 7i8
- jools
- Thank you received: 15
17 Oct 2019 12:55 #148115
by jools
Does anyone have a link to a good tutorial on flashing a Mesa card 7i96e and 7i8 was created by jools
As the title says prefferably a video if possible.
Cheers
Jools
Cheers
Jools
The following user(s) said Thank You: TheFabricatorAG
- Thank you received: 7478
17 Oct 2019 13:47 - 17 Oct 2019 13:49 #148118
Replied by tommylight on topic Does anyone have a link to a good tutorial on flashing a Mesa card 7i96e and 7i8
sudo mesaflash --board_type --readhmid
for normal PCI or PCI-E cards
For ethernet:
sudo mesaflash --device 7i96 --addr 10.10.10.10 --readhmid
Granted your board IP is set at 10.10.10.10 , or 192.168.1.121 from factory
For flashing the card
sudo mesaflash --device 7i96 --addr 10.10.10.10 --write name_of_the_file.bin
the bin file needs to be in the same directory as mesaflash utility
then
sudo mesaflash --device 7i96 --addr 10.10.10.10 --reload
then
sudo mesaflash --device 7i96 --addr 10.10.10.10 --readhmid.
For ethernet:
then
then
Last edit: 17 Oct 2019 13:49 by tommylight. Reason: edited card number
- Thank you received: 5326
17 Oct 2019 14:44 #148122
Replied by PCW on topic Does anyone have a link to a good tutorial on flashing a Mesa card 7i96e and 7i8
A few minor nits:
1. You normally write .bit files with mesaflash
2. You don't need sudo for Ethernet cards
3. You don't need to specify the IP address if the card is set for 192.168.1.121
- jools
18 Oct 2019 13:24 #148199
by jools
Replied by jools on topic Does anyone have a link to a good tutorial on flashing a Mesa card 7i96e and 7i8
So for the 7i96 I power it up with 5v into the P3 connector while connected to ethernet.
Having downloaded mesaflash I make sure the correct .bin file is in the same directory. - Which .bin file do I choose and where is it? The file I downloaded from Mesa contains .pin and .bit.
Also which file do I choose? are there explanations of which ones are for which setup somewhere?
Confused on IP address now with the two comments. Documentation says default is 192.168.1.121 - Does this change Tommy's instructions? If so how?
Do I need to flash the 7i85s?
Also as a seperate can I connect my home switches direct to the inputs and drive them from that? Looking to go with fotek proximities NC which have a 6v to 30v operating window. Any help with if they need a seperate power supply or not and how to wire would be cool too.
Cheers
Jools
Cheers
Jools
18 Oct 2019 14:22 #148203
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
Ip is set from the factory to 192.168.1.121 but there is a jumper on the board to have it set at 10.10.10.10.
7i96 inputs can be used for NPN or PNP switches so any will do, just the wiring changes a bit.
You do need a separate power supply for the field power on the 7i96 and you can use that same source to power the switches.
The following user(s) said Thank You: jools
18 Oct 2019 14:23 #148204
If you have a 7I85S you will need 7i96_7i85sd.bit firmware
The IP address (192.168.1.121 or 10.10.10.10) depends on 7I96 jumpering
(see the 7I96 manual)
There is no firmware on the 7I85S
Looks like the 7i96_7i85sd firmware is not in the 7i96 zip file but here it is:
freeby.mesanet.com/7i96_7i85sd.bit
You can connect the proximity sensor outputs directly to the 7I96 isolated inputs
If you have NPN sensors you would connect the 7I96 input common to +12 or +24V
If you have PNP sensors you would connect the 7I96 input common to ground
- jools
21 Oct 2019 19:49 #148487
by jools
Are there any wiring diagrams anywhere for the 7i96 and 7i85 combo?
21 Oct 2019 21:47 #148496
You will need a DB25 cable, if you already do not have one.
Get is from:
mesanet.com
mesaus.com
eusurplus.com
Get is from:
mesanet.com
mesaus.com
eusurplus.com
21 Oct 2019 21:52 #148497
@Jools,
Hmmmmm, why does your IP say you are in China ? are you using a proxy or VPN?
I cat try to mail you one since i have plenty of them, just to check if our f@#$% post office is usable. Had terrible service before, so maybe, just maybe they got their sh1t together.
- jools
22 Oct 2019 08:07 #148534
by jools
Ha I have no idea why my IP is Chinese though when I login on a new Apple device to my iCloud it does normally tell me that someone in London/MiltonKeynes or anyone else down south is logging on; I'm based in Lincoln though.....
Any chance you could take a photo of one and upload it here?
I have a block to 26 pin block to DB25 cable coming in the post tomorrow.
Cheers
Cheers
- Driver Boards
Time to create page: 0.162 seconds
