Mesa 7i76E - Problem
- Cynas
- Thank you received: 3
24 Oct 2019 19:42 #148736
by Cynas
Mesa 7i76E - Problem was created by Cynas
Hi, I have a problem running the configuration for 7i76E.
ip a
ping 10.10.10.10
mesaflash --device 7i76e --addr 10.10.10.10 --readhmi
uname -v
my ini file ( created pncconf )
my hal file ( created pncconf )
I get an error on startup
What did I do wrong ??
ip a
root@fadalvmc15:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 00:26:b9:86:93:a9 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/24 brd 10.10.10.255 scope global eth0
inet6 fe80::226:b9ff:fe86:93a9/64 scope link
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 20:e7:17:01:52:e0 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.7/24 brd 192.168.1.255 scope global dynamic wlan0
valid_lft 85766sec preferred_lft 85766sec
inet6 fe80::5d8a:d61c:b1dc:ad6/64 scope link
root@fadalvmc15:~# ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10): 56 data bytes
64 bytes from 10.10.10.10: icmp_seq=0 ttl=64 time=0.577 ms
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.102 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.097 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.093 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.256 ms
^C--- 10.10.10.10 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.093/0.225/0.577/0.186 ms
root@fadalvmc15:~# mesaflash --device 7i76e --addr 10.10.10.10 --readhmi
Configuration Name: HOSTMOT2
BoardName : MESA7I76
FPGA Size: 16 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: QCount
There are 1 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for on-card
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData1 (Out)
8 11 IOPort SSerial 0 RXData1 (In)
9 12 IOPort SSerial 0 TXData2 (Out)
10 13 IOPort SSerial 0 RXData2 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P1
1 17 IOPort None
14 18 IOPort None
2 19 IOPort None
15 20 IOPort None
3 21 IOPort None
16 22 IOPort None
4 23 IOPort None
17 24 IOPort None
5 25 IOPort None
6 26 IOPort None
7 27 IOPort None
8 28 IOPort None
9 29 IOPort None
10 30 IOPort None
11 31 IOPort None
12 32 IOPort None
13 33 IOPort None
IO Connections for P2
1 34 IOPort None
14 35 IOPort None
2 36 IOPort None
15 37 IOPort None
3 38 IOPort None
16 39 IOPort None
4 40 IOPort None
17 41 IOPort None
5 42 IOPort None
6 43 IOPort None
7 44 IOPort None
8 45 IOPort None
9 46 IOPort None
10 47 IOPort None
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
root@fadalvmc15:~# uname -v
#1 SMP PREEMPT RT Debian 4.9.110-3+deb9u5 (2018-09-30)
root@fadalvmc15:~# my ini file ( created pncconf )
# Generated by PNCconf at Thu Oct 24 14:00:51 2019
# overwritten when you run PNCconf again
[EMC]
MACHINE = my_LinuxCNC_machine
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /root/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_eth
# BOARD0=7i76e
[HAL]
HALUI = halui
HALFILE = my_LinuxCNC_machine.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 2.50
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
STEPGEN_MAXVEL = 31.25
STEPGEN_MAXACCEL = 937.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 200.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 200.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200.0
HOME_OFFSET = 0.0
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 200.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.01
HOME_OFFSET = 0.0
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000my hal file ( created pncconf )
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=0 num_pwmgens=0 num_stepgens=3 sserial_port_0=00xxxx"
setp hm2_7i76e.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_7i76e.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_7i76e.0.write servo-thread
setp hm2_7i76e.0.dpll.01.timer-us -50
setp hm2_7i76e.0.stepgen.timer-number 1
# external output signals
# external input signals
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp pid.x.error-previous-target true
setp pid.x.maxerror .0005
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-vel-cmd => pid.x.command-deriv
net x-pos-fb => pid.x.feedback
net x-output => pid.x.output
# Step Gen signals/setup
setp hm2_7i76e.0.stepgen.00.dirsetup [AXIS_0]DIRSETUP
setp hm2_7i76e.0.stepgen.00.dirhold [AXIS_0]DIRHOLD
setp hm2_7i76e.0.stepgen.00.steplen [AXIS_0]STEPLEN
setp hm2_7i76e.0.stepgen.00.stepspace [AXIS_0]STEPSPACE
setp hm2_7i76e.0.stepgen.00.position-scale [AXIS_0]STEP_SCALE
setp hm2_7i76e.0.stepgen.00.step_type 0
setp hm2_7i76e.0.stepgen.00.control-type 1
setp hm2_7i76e.0.stepgen.00.maxaccel [AXIS_0]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.00.maxvel [AXIS_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd <= axis.0.motor-pos-cmd
net x-vel-cmd <= axis.0.joint-vel-cmd
net x-output => hm2_7i76e.0.stepgen.00.velocity-cmd
net x-pos-fb <= hm2_7i76e.0.stepgen.00.position-fb
net x-pos-fb => axis.0.motor-pos-fb
net x-enable <= axis.0.amp-enable-out
net x-enable => hm2_7i76e.0.stepgen.00.enable
# ---setup home / limit switch signals---
net x-home-sw => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp pid.y.error-previous-target true
setp pid.y.maxerror .0005
net y-index-enable <=> pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-vel-cmd => pid.y.command-deriv
net y-pos-fb => pid.y.feedback
net y-output => pid.y.output
setp hm2_7i76e.0.stepgen.01.dirsetup [AXIS_1]DIRSETUP
setp hm2_7i76e.0.stepgen.01.dirhold [AXIS_1]DIRHOLD
setp hm2_7i76e.0.stepgen.01.steplen [AXIS_1]STEPLEN
setp hm2_7i76e.0.stepgen.01.stepspace [AXIS_1]STEPSPACE
setp hm2_7i76e.0.stepgen.01.position-scale [AXIS_1]STEP_SCALE
setp hm2_7i76e.0.stepgen.01.step_type 0
setp hm2_7i76e.0.stepgen.01.control-type 1
setp hm2_7i76e.0.stepgen.01.maxaccel [AXIS_1]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.01.maxvel [AXIS_1]STEPGEN_MAXVEL
net y-pos-cmd <= axis.1.motor-pos-cmd
net y-vel-cmd <= axis.1.joint-vel-cmd
net y-output => hm2_7i76e.0.stepgen.01.velocity-cmd
net y-pos-fb <= hm2_7i76e.0.stepgen.01.position-fb
net y-pos-fb => axis.1.motor-pos-fb
net y-enable <= axis.1.amp-enable-out
net y-enable => hm2_7i76e.0.stepgen.01.enable
net y-home-sw => axis.1.home-sw-in
net y-neg-limit => axis.1.neg-lim-sw-in
net y-pos-limit => axis.1.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp pid.z.error-previous-target true
setp pid.z.maxerror .0005
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-vel-cmd => pid.z.command-deriv
net z-pos-fb => pid.z.feedback
net z-output => pid.z.output
setp hm2_7i76e.0.stepgen.02.dirsetup [AXIS_2]DIRSETUP
setp hm2_7i76e.0.stepgen.02.dirhold [AXIS_2]DIRHOLD
setp hm2_7i76e.0.stepgen.02.steplen [AXIS_2]STEPLEN
setp hm2_7i76e.0.stepgen.02.stepspace [AXIS_2]STEPSPACE
setp hm2_7i76e.0.stepgen.02.position-scale [AXIS_2]STEP_SCALE
setp hm2_7i76e.0.stepgen.02.step_type 0
setp hm2_7i76e.0.stepgen.02.control-type 1
setp hm2_7i76e.0.stepgen.02.maxaccel [AXIS_2]STEPGEN_MAXACCEL
setp hm2_7i76e.0.stepgen.02.maxvel [AXIS_2]STEPGEN_MAXVEL
net z-pos-cmd <= axis.2.motor-pos-cmd
net z-vel-cmd <= axis.2.joint-vel-cmd
net z-output => hm2_7i76e.0.stepgen.02.velocity-cmd
net z-pos-fb <= hm2_7i76e.0.stepgen.02.position-fb
net z-pos-fb => axis.2.motor-pos-fb
net z-enable <= axis.2.amp-enable-out
net z-enable => hm2_7i76e.0.stepgen.02.enable
net z-home-sw => axis.2.home-sw-in
net z-neg-limit => axis.2.neg-lim-sw-in
net z-pos-limit => axis.2.pos-lim-sw-in
# SPINDLE S
setp pid.s.Pgain [SPINDLE_9]P
setp pid.s.Igain [SPINDLE_9]I
setp pid.s.Dgain [SPINDLE_9]D
setp pid.s.bias [SPINDLE_9]BIAS
setp pid.s.FF0 [SPINDLE_9]FF0
setp pid.s.FF1 [SPINDLE_9]FF1
setp pid.s.FF2 [SPINDLE_9]FF2
setp pid.s.deadband [SPINDLE_9]DEADBAND
setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp pid.s.error-previous-target true
net spindle-index-enable <=> pid.s.index-enable
net spindle-enable => pid.s.enable
net spindle-vel-cmd-rpm => pid.s.command
net spindle-vel-fb-rpm => pid.s.feedback
net spindle-output <= pid.s.output
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb-rps => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net joint-select-a halui.joint.0.select
net x-is-homed halui.joint.0.is-homed
net jog-x-pos halui.jog.0.plus
net jog-x-neg halui.jog.0.minus
net jog-x-analog halui.jog.0.analog
net joint-select-b halui.joint.1.select
net y-is-homed halui.joint.1.is-homed
net jog-y-pos halui.jog.1.plus
net jog-y-neg halui.jog.1.minus
net jog-y-analog halui.jog.1.analog
net joint-select-c halui.joint.2.select
net z-is-homed halui.joint.2.is-homed
net jog-z-pos halui.jog.2.plus
net jog-z-neg halui.jog.2.minus
net jog-z-analog halui.jog.2.analog
net jog-selected-pos halui.jog.selected.plus
net jog-selected-neg halui.jog.selected.minus
net spindle-manual-cw halui.spindle.forward
net spindle-manual-ccw halui.spindle.reverse
net spindle-manual-stop halui.spindle.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/root/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/root/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./my_LinuxCNC_machine.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=1819
Debug file information:
Refusing to run as root without fallback UID specified
To run under a debugger with I/O, use e.g.,
sudo env RTAPI_UID=`id -u` RTAPI_FIFO_PATH=$HOME/.rtapi_fifo gdb rtapi_app
./my_LinuxCNC_machine.hal:5: waitpid failed /usr/bin/rtapi_app trivkins
./my_LinuxCNC_machine.hal:5: /usr/bin/rtapi_app exited without becoming ready
./my_LinuxCNC_machine.hal:5: insmod for trivkins failed, returned -1
1819
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Linux version 4.9.0-8-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u5 (2018-09-30)
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Enabled xstate features 0x3, context size is 576 bytes, using 'standard' format.
[ 0.000000] e820: BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000f0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000ddbffbff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ddbffc00-0x00000000ddc53bff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000ddc53c00-0x00000000ddc55bff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x00000000ddc55c00-0x00000000dfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fed003ff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed9ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x0000000117ffffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 960 /0G261D, BIOS A08 08/03/2010
[ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000000] e820: last_pfn = 0x118000 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: write-back
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0DDE00000 mask FFFE00000 uncachable
[ 0.000000] 1 base 0DE000000 mask FFE000000 uncachable
[ 0.000000] 2 base 0DDD00000 mask FFFF00000 uncachable
[ 0.000000] 3 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- WT
[ 0.000000] found SMP MP-table at [mem 0x000fe710-0x000fe71f] mapped at [c00fe710]
[ 0.000000] initial memory mapped: [mem 0x00000000-0x0effffff]
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] BRK [0x0ea59000, 0x0ea59fff] PGTABLE
[ 0.000000] BRK [0x0ea5a000, 0x0ea5bfff] PGTABLE
[ 0.000000] BRK [0x0ea5c000, 0x0ea5cfff] PGTABLE
[ 0.000000] BRK [0x0ea5d000, 0x0ea5dfff] PGTABLE
[ 0.000000] RAMDISK: [mem 0x353af000-0x369cefff]
[ 0.000000] ACPI: Early table checksum verification disabled
[ 0.000000] ACPI: RSDP 0x00000000000FEC00 000024 (v02 DELL )
[ 0.000000] ACPI: XSDT 0x00000000000FC7D7 00008C (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: FACP 0x00000000000FC907 0000F4 (v03 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe0Block: 128/64 (20160831/tbfadt-603)
[ 0.000000] ACPI: DSDT 0x00000000FFE9E67D 005744 (v01 DELL dt_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: FACS 0x00000000DDBFFC00 000040
[ 0.000000] ACPI: SSDT 0x00000000FFEA3EE0 0000AA (v01 DELL st_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: APIC 0x00000000000FC9FB 000092 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: BOOT 0x00000000000FCA8D 000028 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: ASF! 0x00000000000FCAB5 000096 (v32 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: MCFG 0x00000000000FCB4B 00003C (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: HPET 0x00000000000FCB87 000038 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: TCPA 0x00000000000FCDE3 000032 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: ____ 0x00000000000FCE15 000030 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: SLIC 0x00000000000FCBBF 000176 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: SSDT 0x00000000DDBFFC40 00027D (v01 DpgPmm Cpu0Ist 00000011 INTL 20050624)
[ 0.000000] ACPI: SSDT 0x00000000DDC00049 00027D (v01 DpgPmm Cpu1Ist 00000011 INTL 20050624)
[ 0.000000] ACPI: SSDT 0x00000000DDC00452 000190 (v01 DpgPmm CpuPm 00000010 INTL 20050624)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 3590MB HIGHMEM available.
[ 0.000000] 889MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 379fe000
[ 0.000000] low ram: 0 - 379fe000
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.000000] Normal [mem 0x0000000001000000-0x00000000379fdfff]
[ 0.000000] HighMem [mem 0x00000000379fe000-0x0000000117ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.000000] node 0: [mem 0x0000000000100000-0x00000000ddbfefff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x0000000117ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x0000000117ffffff]
[ 0.000000] On node 0 totalpages: 1006493
[ 0.000000] free_area_init_node: node 0, pgdat ce829780, node_mem_map f27ef028
[ 0.000000] DMA zone: 40 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3998 pages, LIFO batch:0
[ 0.000000] Normal zone: 2185 pages used for memmap
[ 0.000000] Normal zone: 223742 pages, LIFO batch:31
[ 0.000000] HighMem zone: 778753 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] Reserving Intel graphics memory at 0x00000000de000000-0x00000000dfffffff
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] smpboot: Allowing 8 CPUs, 6 hotplug CPUs
[ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x000effff]
[ 0.000000] PM: Registered nosave memory: [mem 0x000f0000-0x000fffff]
[ 0.000000] e820: [mem 0xe0000000-0xf7ffffff] available for PCI devices
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] percpu: Embedded 101 pages/cpu @f76d3000 s381472 r0 d32224 u413696
[ 0.000000] pcpu-alloc: s381472 r0 d32224 u413696 alloc=101*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1004268
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-686-pae root=/dev/sda1 ro quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] microcode: microcode updated early to revision 0xa0b, date = 2010-09-28
[ 0.000000] Initializing CPU#0
[ 0.000000] Initializing HighMem for node 0 (000379fe:00118000)
[ 0.000000] Initializing Movable for node 0 (00000000:00000000)
[ 0.000000] Memory: 3943284K/4025972K available (6035K kernel code, 628K rwdata, 1756K rodata, 1060K init, 592K bss, 82688K reserved, 0K cma-reserved, 3115012K highmem)
[ 0.000000] virtual kernel memory layout:
fixmap : 0xffd36000 - 0xfffff000 (2852 kB)
pkmap : 0xffa00000 - 0xffc00000 (2048 kB)
vmalloc : 0xf81fe000 - 0xff9fe000 ( 120 MB)
lowmem : 0xc0000000 - 0xf79fe000 ( 889 MB)
.init : 0xce83d000 - 0xce946000 (1060 kB)
.data : 0xce5e51f4 - 0xce83b280 (2392 kB)
.text : 0xce000000 - 0xce5e51f4 (6036 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=8.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.000000] NR_IRQS:2304 nr_irqs:488 16
[ 0.000000] CPU 0 irqstacks, hard=f7082000 soft=f7084000
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[ 0.000000] hpet clockevent registered
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 3058.819 MHz processor
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 6117.63 BogoMIPS (lpj=12235276)
[ 0.004005] pid_max: default: 32768 minimum: 301
[ 0.008013] ACPI: Core revision 20160831
[ 0.088742] ACPI: 5 ACPI AML tables successfully acquired and loaded
[ 0.088765] Security Framework initialized
[ 0.088767] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.088775] AppArmor: AppArmor disabled by boot time parameter
[ 0.088786] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.088787] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.089081] mce: CPU supports 6 MCE banks
[ 0.089088] CPU0: Thermal monitoring enabled (TM2)
[ 0.089091] process: using mwait in idle threads
[ 0.089099] Last level iTLB entries: 4KB 128, 2MB 4, 4MB 4
[ 0.089099] Last level dTLB entries: 4KB 256, 2MB 0, 4MB 32, 1GB 0
[ 0.089101] Spectre V2 : Mitigation: Full generic retpoline
[ 0.089102] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.089103] Speculative Store Bypass: Vulnerable
[ 0.089337] Freeing SMP alternatives memory: 24K
[ 0.090309] ftrace: allocating 24078 entries in 48 pages
[ 0.104107] smpboot: Max logical packages: 4
[ 0.104115] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.104487] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.148000] smpboot: CPU0: Intel(R) Core(TM)2 Duo CPU E7600 @ 3.06GHz (family: 0x6, model: 0x17, stepping: 0xa)
[ 0.148000] Performance Events: PEBS fmt0+, Core2 events, Intel PMU driver.
[ 0.148000] ... version: 2
[ 0.148000] ... bit width: 40
[ 0.148000] ... generic registers: 2
[ 0.148000] ... value mask: 000000ffffffffff
[ 0.148000] ... max period: 000000007fffffff
[ 0.148000] ... fixed-purpose events: 3
[ 0.148000] ... event mask: 0000000700000003
[ 0.200328] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[ 0.252032] CPU 1 irqstacks, hard=f7222000 soft=f7224000
[ 0.252034] x86: Booting SMP configuration:
[ 0.252036] .... node #0, CPUs: #1
[ 0.008000] Initializing CPU#1
[ 0.258079] x86: Booted up 1 node, 2 CPUs
[ 0.258079] smpboot: Total of 2 processors activated (12235.27 BogoMIPS)
[ 0.260227] devtmpfs: initialized
[ 0.260289] PM: Registering ACPI NVS region [mem 0xddbffc00-0xddc53bff] (344064 bytes)
[ 0.260373] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.260377] futex hash table entries: 2048 (order: 5, 131072 bytes)
[ 0.260442] pinctrl core: initialized pinctrl subsystem
[ 0.260598] NET: Registered protocol family 16
[ 0.264025] cpuidle: using governor ladder
[ 0.268021] cpuidle: using governor menu
[ 0.268064] Simple Boot Flag at 0x7a set to 0x1
[ 0.268080] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.268082] ACPI: bus type PCI registered
[ 0.268085] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.268198] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.268200] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.268200] PCI: Using MMCONFIG for extended config space
[ 0.268201] PCI: Using configuration type 1 for base access
[ 0.268212] dmi type 0xB1 record - unknown flag
[ 0.269113] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.269113] ACPI: Added _OSI(Module Device)
[ 0.269113] ACPI: Added _OSI(Processor Device)
[ 0.269113] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.269113] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.308055] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.346302] ACPI: Interpreter enabled
[ 0.346326] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.346327] ACPI: Using IOAPIC for interrupt routing
[ 0.346437] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.358087] acpi LNXIOBAY:00: ACPI dock station (docks/bays count: 1)
[ 0.534771] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.534775] acpi PNP0A03:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[ 0.534779] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[ 0.534783] acpi PNP0A03:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[ 0.543457] PCI host bridge to bus 0000:00
[ 0.543460] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.543462] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.543463] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.543465] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000effff window]
[ 0.543466] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[ 0.543468] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfec00000 window]
[ 0.543469] pci_bus 0000:00: root bus resource [mem 0xddd00000-0xf7ffffff window]
[ 0.543471] pci_bus 0000:00: root bus resource [mem 0xff980000-0xff980fff window]
[ 0.543472] pci_bus 0000:00: root bus resource [mem 0xff97c000-0xff97ffff window]
[ 0.543474] pci_bus 0000:00: root bus resource [mem 0xff970000-0xff9707ff window]
[ 0.543475] pci_bus 0000:00: root bus resource [mem 0xfed20000-0xfed9ffff window]
[ 0.543477] pci_bus 0000:00: root bus resource [mem 0xfeda6000-0xfeda6fff window]
[ 0.543478] pci_bus 0000:00: root bus resource [mem 0xfeda7000-0xfeda7fff window]
[ 0.543480] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.543489] pci 0000:00:00.0: [8086:2e10] type 00 class 0x060000
[ 0.544062] pci 0000:00:01.0: [8086:2e11] type 01 class 0x060400
[ 0.544100] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.544402] pci 0000:00:01.0: System wakeup disabled by ACPI
[ 0.544448] pci 0000:00:02.0: [8086:2e12] type 00 class 0x030000
[ 0.544458] pci 0000:00:02.0: reg 0x10: [mem 0xf7c00000-0xf7ffffff 64bit]
[ 0.544464] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.544468] pci 0000:00:02.0: reg 0x20: [io 0xecb0-0xecb7]
[ 0.544824] pci 0000:00:02.1: [8086:2e13] type 00 class 0x038000
[ 0.544833] pci 0000:00:02.1: reg 0x10: [mem 0xf7b00000-0xf7bfffff 64bit]
[ 0.545195] pci 0000:00:03.0: [8086:2e14] type 00 class 0x078000
[ 0.545207] pci 0000:00:03.0: reg 0x10: [mem 0xfeda6000-0xfeda600f 64bit]
[ 0.545249] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.545591] pci 0000:00:03.2: [8086:2e16] type 00 class 0x010185
[ 0.545610] pci 0000:00:03.2: reg 0x10: [io 0xfe80-0xfe87]
[ 0.545620] pci 0000:00:03.2: reg 0x14: [io 0xfe90-0xfe93]
[ 0.545629] pci 0000:00:03.2: reg 0x18: [io 0xfea0-0xfea7]
[ 0.545639] pci 0000:00:03.2: reg 0x1c: [io 0xfeb0-0xfeb3]
[ 0.545649] pci 0000:00:03.2: reg 0x20: [io 0xfef0-0xfeff]
[ 0.546039] pci 0000:00:03.3: [8086:2e17] type 00 class 0x070002
[ 0.546050] pci 0000:00:03.3: reg 0x10: [io 0xecb8-0xecbf]
[ 0.546055] pci 0000:00:03.3: reg 0x14: [mem 0xf7ad8000-0xf7ad8fff]
[ 0.546450] pci 0000:00:19.0: [8086:10de] type 00 class 0x020000
[ 0.546464] pci 0000:00:19.0: reg 0x10: [mem 0xf7ae0000-0xf7afffff]
[ 0.546472] pci 0000:00:19.0: reg 0x14: [mem 0xf7ad9000-0xf7ad9fff]
[ 0.546479] pci 0000:00:19.0: reg 0x18: [io 0xece0-0xecff]
[ 0.546534] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.546872] pci 0000:00:1a.0: [8086:3a67] type 00 class 0x0c0300
[ 0.546910] pci 0000:00:1a.0: reg 0x20: [io 0xff20-0xff3f]
[ 0.547241] pci 0000:00:1a.0: System wakeup disabled by ACPI
[ 0.547291] pci 0000:00:1a.1: [8086:3a68] type 00 class 0x0c0300
[ 0.547329] pci 0000:00:1a.1: reg 0x20: [io 0xff00-0xff1f]
[ 0.547662] pci 0000:00:1a.1: System wakeup disabled by ACPI
[ 0.547712] pci 0000:00:1a.2: [8086:3a69] type 00 class 0x0c0300
[ 0.547749] pci 0000:00:1a.2: reg 0x20: [io 0xfc00-0xfc1f]
[ 0.548087] pci 0000:00:1a.2: System wakeup disabled by ACPI
[ 0.548144] pci 0000:00:1a.7: [8086:3a6c] type 00 class 0x0c0320
[ 0.548160] pci 0000:00:1a.7: reg 0x10: [mem 0xf7ada000-0xf7ada3ff]
[ 0.548239] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.548582] pci 0000:00:1b.0: [8086:3a6e] type 00 class 0x040300
[ 0.548598] pci 0000:00:1b.0: reg 0x10: [mem 0xf7adc000-0xf7adffff 64bit]
[ 0.548664] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.549011] pci 0000:00:1c.0: [8086:3a70] type 01 class 0x060400
[ 0.549076] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.549382] pci 0000:00:1c.0: System wakeup disabled by ACPI
[ 0.549434] pci 0000:00:1c.1: [8086:3a72] type 01 class 0x060400
[ 0.549498] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.549805] pci 0000:00:1c.1: System wakeup disabled by ACPI
[ 0.549860] pci 0000:00:1d.0: [8086:3a64] type 00 class 0x0c0300
[ 0.549898] pci 0000:00:1d.0: reg 0x20: [io 0xff80-0xff9f]
[ 0.550228] pci 0000:00:1d.0: System wakeup disabled by ACPI
[ 0.550278] pci 0000:00:1d.1: [8086:3a65] type 00 class 0x0c0300
[ 0.550316] pci 0000:00:1d.1: reg 0x20: [io 0xff60-0xff7f]
[ 0.550647] pci 0000:00:1d.1: System wakeup disabled by ACPI
[ 0.550695] pci 0000:00:1d.2: [8086:3a66] type 00 class 0x0c0300
[ 0.550732] pci 0000:00:1d.2: reg 0x20: [io 0xff40-0xff5f]
[ 0.551063] pci 0000:00:1d.2: System wakeup disabled by ACPI
[ 0.551120] pci 0000:00:1d.7: [8086:3a6a] type 00 class 0x0c0320
[ 0.551136] pci 0000:00:1d.7: reg 0x10: [mem 0xff980000-0xff9803ff]
[ 0.551214] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.551560] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.551900] pci 0000:00:1e.0: System wakeup disabled by ACPI
[ 0.551952] pci 0000:00:1f.0: [8086:3a14] type 00 class 0x060100
[ 0.552386] pci 0000:00:1f.2: [8086:3a00] type 00 class 0x01018a
[ 0.552398] pci 0000:00:1f.2: reg 0x10: [io 0x01f0-0x01f7]
[ 0.552405] pci 0000:00:1f.2: reg 0x14: [io 0x03f4-0x03f7]
[ 0.552412] pci 0000:00:1f.2: reg 0x18: [io 0x0170-0x0177]
[ 0.552419] pci 0000:00:1f.2: reg 0x1c: [io 0x0374-0x0377]
[ 0.552425] pci 0000:00:1f.2: reg 0x20: [io 0xfec0-0xfecf]
[ 0.552432] pci 0000:00:1f.2: reg 0x24: [io 0xecc0-0xeccf]
[ 0.552441] pci 0000:00:1f.2: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7]
[ 0.552443] pci 0000:00:1f.2: legacy IDE quirk: reg 0x14: [io 0x03f6]
[ 0.552444] pci 0000:00:1f.2: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177]
[ 0.552445] pci 0000:00:1f.2: legacy IDE quirk: reg 0x1c: [io 0x0376]
[ 0.552802] pci 0000:00:1f.3: [8086:3a60] type 00 class 0x0c0500
[ 0.552816] pci 0000:00:1f.3: reg 0x10: [mem 0xf7adb000-0xf7adb0ff 64bit]
[ 0.552835] pci 0000:00:1f.3: reg 0x20: [io 0x0940-0x095f]
[ 0.553185] pci 0000:00:1f.5: [8086:3a06] type 00 class 0x010185
[ 0.553197] pci 0000:00:1f.5: reg 0x10: [io 0xfe40-0xfe47]
[ 0.553204] pci 0000:00:1f.5: reg 0x14: [io 0xfe50-0xfe53]
[ 0.553211] pci 0000:00:1f.5: reg 0x18: [io 0xfe60-0xfe67]
[ 0.553217] pci 0000:00:1f.5: reg 0x1c: [io 0xfe70-0xfe73]
[ 0.553224] pci 0000:00:1f.5: reg 0x20: [io 0xfed0-0xfedf]
[ 0.553231] pci 0000:00:1f.5: reg 0x24: [io 0xecd0-0xecdf]
[ 0.553622] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.553626] pci 0000:00:01.0: bridge window [mem 0xf7900000-0xf79fffff]
[ 0.553676] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.553681] pci 0000:00:1c.0: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.553729] pci 0000:00:1c.1: PCI bridge to [bus 03]
[ 0.553734] pci 0000:00:1c.1: bridge window [mem 0xf7700000-0xf77fffff]
[ 0.553807] pci 0000:00:1e.0: PCI bridge to [bus 04] (subtractive decode)
[ 0.553815] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode)
[ 0.553817] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode)
[ 0.553818] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[ 0.553820] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000effff window] (subtractive decode)
[ 0.553821] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff window] (subtractive decode)
[ 0.553822] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfec00000 window] (subtractive decode)
[ 0.553824] pci 0000:00:1e.0: bridge window [mem 0xddd00000-0xf7ffffff window] (subtractive decode)
[ 0.553825] pci 0000:00:1e.0: bridge window [mem 0xff980000-0xff980fff window] (subtractive decode)
[ 0.553827] pci 0000:00:1e.0: bridge window [mem 0xff97c000-0xff97ffff window] (subtractive decode)
[ 0.553828] pci 0000:00:1e.0: bridge window [mem 0xff970000-0xff9707ff window] (subtractive decode)
[ 0.553830] pci 0000:00:1e.0: bridge window [mem 0xfed20000-0xfed9ffff window] (subtractive decode)
[ 0.553831] pci 0000:00:1e.0: bridge window [mem 0xfeda6000-0xfeda6fff window] (subtractive decode)
[ 0.553833] pci 0000:00:1e.0: bridge window [mem 0xfeda7000-0xfeda7fff window] (subtractive decode)
[ 0.553849] pci_bus 0000:00: on NUMA node 0
[ 0.581358] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 0.582253] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.583135] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 0.584077] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.584989] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.585870] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 0.586769] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.587650] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.588330] ACPI: Enabled 2 GPEs in block 00 to 3F
[ 0.588418] vgaarb: setting as boot device: PCI:0000:00:02.0
[ 0.588418] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.588418] vgaarb: loaded
[ 0.588418] vgaarb: bridge control possible 0000:00:02.0
[ 0.588418] PCI: Using ACPI for IRQ routing
[ 0.589369] PCI: pci_cache_line_size set to 64 bytes
[ 0.589423] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 0.589424] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 0.589426] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[ 0.589428] e820: reserve RAM buffer [mem 0xddbffc00-0xdfffffff]
[ 0.589682] HPET: 8 timers in total, 5 timers will be used for per-cpu timer
[ 0.589687] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 24, 25, 26, 27, 28, 0
[ 0.589693] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.592030] hpet: hpet2 irq 24 for MSI
[ 0.592040] hpet: hpet3 irq 25 for MSI
[ 0.592042] clocksource: Switched to clocksource hpet
[ 0.604511] VFS: Disk quotas dquot_6.6.0
[ 0.604536] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.604662] pnp: PnP ACPI init
[ 0.608570] system 00:00: [io 0x0800-0x085f] has been reserved
[ 0.608572] system 00:00: [io 0x0c00-0x0c7f] has been reserved
[ 0.608574] system 00:00: [io 0x0860-0x08ff] has been reserved
[ 0.608579] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.608815] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.622907] pnp 00:02: [dma 0 disabled]
[ 0.624109] pnp 00:02: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.629434] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.644460] pnp: PnP ACPI: found 4 devices
[ 0.644463] PnPBIOS: Disabled by ACPI PNP
[ 0.681759] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.681779] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02] add_size 1000
[ 0.681781] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[ 0.681788] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 03] add_size 1000
[ 0.681790] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[ 0.681804] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.681806] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.681808] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.681810] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[ 0.681811] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.681813] pci 0000:00:1c.0: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.681815] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.681816] pci 0000:00:1c.1: res[13]=[io 0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[ 0.681832] pci 0000:00:1c.0: BAR 15: assigned [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 0.681840] pci 0000:00:1c.1: BAR 15: assigned [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 0.681844] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 0.681846] pci 0000:00:1c.1: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.681849] pci 0000:00:01.0: PCI bridge to [bus 01]
[ 0.681853] pci 0000:00:01.0: bridge window [mem 0xf7900000-0xf79fffff]
[ 0.681857] pci 0000:00:1c.0: PCI bridge to [bus 02]
[ 0.681860] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 0.681863] pci 0000:00:1c.0: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.681867] pci 0000:00:1c.0: bridge window [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 0.681871] pci 0000:00:1c.1: PCI bridge to [bus 03]
[ 0.681873] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 0.681877] pci 0000:00:1c.1: bridge window [mem 0xf7700000-0xf77fffff]
[ 0.681880] pci 0000:00:1c.1: bridge window [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 0.681886] pci 0000:00:1e.0: PCI bridge to [bus 04]
[ 0.681896] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.681897] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.681899] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.681900] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000effff window]
[ 0.681902] pci_bus 0000:00: resource 8 [mem 0x000f0000-0x000fffff window]
[ 0.681903] pci_bus 0000:00: resource 9 [mem 0xfc000000-0xfec00000 window]
[ 0.681905] pci_bus 0000:00: resource 10 [mem 0xddd00000-0xf7ffffff window]
[ 0.681906] pci_bus 0000:00: resource 11 [mem 0xff980000-0xff980fff window]
[ 0.681907] pci_bus 0000:00: resource 12 [mem 0xff97c000-0xff97ffff window]
[ 0.681909] pci_bus 0000:00: resource 13 [mem 0xff970000-0xff9707ff window]
[ 0.681910] pci_bus 0000:00: resource 14 [mem 0xfed20000-0xfed9ffff window]
[ 0.681912] pci_bus 0000:00: resource 15 [mem 0xfeda6000-0xfeda6fff window]
[ 0.681913] pci_bus 0000:00: resource 16 [mem 0xfeda7000-0xfeda7fff window]
[ 0.681915] pci_bus 0000:01: resource 1 [mem 0xf7900000-0xf79fffff]
[ 0.681917] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 0.681918] pci_bus 0000:02: resource 1 [mem 0xf7800000-0xf78fffff]
[ 0.681920] pci_bus 0000:02: resource 2 [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 0.681921] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 0.681923] pci_bus 0000:03: resource 1 [mem 0xf7700000-0xf77fffff]
[ 0.681924] pci_bus 0000:03: resource 2 [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 0.681926] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7 window]
[ 0.681928] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff window]
[ 0.681929] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.681931] pci_bus 0000:04: resource 7 [mem 0x000c0000-0x000effff window]
[ 0.681932] pci_bus 0000:04: resource 8 [mem 0x000f0000-0x000fffff window]
[ 0.681934] pci_bus 0000:04: resource 9 [mem 0xfc000000-0xfec00000 window]
[ 0.681935] pci_bus 0000:04: resource 10 [mem 0xddd00000-0xf7ffffff window]
[ 0.681937] pci_bus 0000:04: resource 11 [mem 0xff980000-0xff980fff window]
[ 0.681938] pci_bus 0000:04: resource 12 [mem 0xff97c000-0xff97ffff window]
[ 0.681939] pci_bus 0000:04: resource 13 [mem 0xff970000-0xff9707ff window]
[ 0.681941] pci_bus 0000:04: resource 14 [mem 0xfed20000-0xfed9ffff window]
[ 0.681942] pci_bus 0000:04: resource 15 [mem 0xfeda6000-0xfeda6fff window]
[ 0.681944] pci_bus 0000:04: resource 16 [mem 0xfeda7000-0xfeda7fff window]
[ 0.682000] NET: Registered protocol family 2
[ 0.682188] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.682211] TCP bind hash table entries: 8192 (order: 5, 229376 bytes)
[ 0.682321] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.682361] UDP hash table entries: 512 (order: 3, 32768 bytes)
[ 0.682378] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[ 0.682461] NET: Registered protocol family 1
[ 0.682477] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.689339] PCI: CLS 64 bytes, default 64
[ 0.689396] Unpacking initramfs...
[ 1.057398] Freeing initrd memory: 22656K
[ 1.058038] audit: initializing netlink subsys (disabled)
[ 1.058062] audit: type=2000 audit(1571944591.056:1): initialized
[ 1.058599] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.060889] zbud: loaded
[ 1.061648] bounce: pool size: 64 pages
[ 1.061693] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 1.061722] io scheduler noop registered
[ 1.061723] io scheduler deadline registered
[ 1.061764] io scheduler cfq registered (default)
[ 1.063483] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.063490] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.063514] intel_idle: does not run on family 6 model 23
[ 1.065108] Monitor-Mwait will be used to enter C-1 state
[ 1.066746] GHES: HEST is not enabled!
[ 1.066766] isapnp: Scanning for PnP cards...
[ 1.419581] isapnp: No Plug & Play device found
[ 1.419668] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.440121] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[ 1.461058] 0000:00:03.3: ttyS1 at I/O 0xecb8 (irq = 17, base_baud = 115200) is a 16550A
[ 1.461445] Linux agpgart interface v0.103
[ 1.461913] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.464728] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.464771] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.464896] mousedev: PS/2 mouse device common for all mice
[ 1.464946] rtc_cmos 00:01: RTC can wake from S4
[ 1.465066] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 1.465109] rtc_cmos 00:01: alarms up to one day, 242 bytes nvram, hpet irqs
[ 1.465914] NET: Registered protocol family 10
[ 1.466198] mip6: Mobile IPv6
[ 1.466201] NET: Registered protocol family 17
[ 1.466203] mpls_gso: MPLS GSO support
[ 1.466379] microcode: sig=0x1067a, pf=0x1, revision=0xa0b
[ 1.466426] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.466430] Using IPI No-Shortcut mode
[ 1.466599] registered taskstats version 1
[ 1.466620] zswap: loaded using pool lzo/zbud
[ 1.466660] ima: No TPM chip found, activating TPM-bypass!
[ 1.466662] ima: Allocated hash algorithm: sha256
[ 1.466986] rtc_cmos 00:01: setting system clock to 2019-10-24 19:16:32 UTC (1571944592)
[ 1.467037] PM: Hibernation image not present or could not be loaded.
[ 1.467544] Freeing unused kernel memory: 1060K
[ 1.467632] Write protecting the kernel text: 6040k
[ 1.467706] Write protecting the kernel read-only data: 1760k
[ 1.467707] NX-protecting the kernel data: 4200k
[ 1.467901] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.481438] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.481519] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[ 1.482507] random: udevadm: uninitialized urandom read (16 bytes read)
[ 1.507264] pps_core: LinuxPPS API ver. 1 registered
[ 1.507267] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.507494] PTP clock support registered
[ 1.509724] ACPI: bus type USB registered
[ 1.509757] usbcore: registered new interface driver usbfs
[ 1.509770] usbcore: registered new interface driver hub
[ 1.510578] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 1.510580] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.511146] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 1.521104] usbcore: registered new device driver usb
[ 1.528912] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.529182] SCSI subsystem initialized
[ 1.533259] ehci-pci: EHCI PCI platform driver
[ 1.533521] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.538414] libata version 3.00 loaded.
[ 1.716377] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:26:b9:86:93:a9
[ 1.716380] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[ 1.716410] e1000e 0000:00:19.0 eth0: MAC: 8, PHY: 8, PBA No: 2021FF-0FF
[ 1.716943] ehci-pci 0000:00:1a.7: EHCI Host Controller
[ 1.716951] ehci-pci 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 1.716962] ehci-pci 0000:00:1a.7: debug port 1
[ 1.720874] ehci-pci 0000:00:1a.7: cache line size of 64 is not supported
[ 1.720926] ehci-pci 0000:00:1a.7: irq 22, io mem 0xf7ada000
[ 1.736042] ehci-pci 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 1.736206] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.736208] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.736210] usb usb1: Product: EHCI Host Controller
[ 1.736211] usb usb1: Manufacturer: Linux 4.9.0-8-rt-686-pae ehci_hcd
[ 1.736212] usb usb1: SerialNumber: 0000:00:1a.7
[ 1.736375] hub 1-0:1.0: USB hub found
[ 1.736385] hub 1-0:1.0: 6 ports detected
[ 1.737046] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 1.737052] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 2
[ 1.737057] uhci_hcd 0000:00:1a.0: detected 2 ports
[ 1.737111] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[ 1.737170] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.737172] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.737173] usb usb2: Product: UHCI Host Controller
[ 1.737175] usb usb2: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.737176] usb usb2: SerialNumber: 0000:00:1a.0
[ 1.737308] hub 2-0:1.0: USB hub found
[ 1.737316] hub 2-0:1.0: 2 ports detected
[ 1.740058] scsi host0: ata_generic
[ 1.740174] scsi host1: ata_generic
[ 1.740233] ata1: PATA max UDMA/100 cmd 0xfe80 ctl 0xfe90 bmdma 0xfef0 irq 18
[ 1.740234] ata2: PATA max UDMA/100 cmd 0xfea0 ctl 0xfeb0 bmdma 0xfef8 irq 18
[ 1.740258] ata_piix 0000:00:1f.2: version 2.13
[ 1.740686] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.904849] scsi host2: ata_piix
[ 1.908968] scsi host3: ata_piix
[ 1.909031] ata3: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xfec0 irq 14
[ 1.909036] ata4: SATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xfec8 irq 15
[ 1.910325] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 1.912236] ehci-pci 0000:00:1d.7: EHCI Host Controller
[ 1.912242] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 3
[ 1.912252] ehci-pci 0000:00:1d.7: debug port 1
[ 1.916168] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[ 1.916258] ehci-pci 0000:00:1d.7: irq 23, io mem 0xff980000
[ 1.932040] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.932130] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.932132] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.932134] usb usb3: Product: EHCI Host Controller
[ 1.932135] usb usb3: Manufacturer: Linux 4.9.0-8-rt-686-pae ehci_hcd
[ 1.932137] usb usb3: SerialNumber: 0000:00:1d.7
[ 1.932296] hub 3-0:1.0: USB hub found
[ 1.932305] hub 3-0:1.0: 6 ports detected
[ 1.933086] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 1.933093] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 1.933098] uhci_hcd 0000:00:1a.1: detected 2 ports
[ 1.933533] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[ 1.933593] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.933594] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.933596] usb usb4: Product: UHCI Host Controller
[ 1.933597] usb usb4: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 1.933599] usb usb4: SerialNumber: 0000:00:1a.1
[ 1.933791] hub 4-0:1.0: USB hub found
[ 1.934029] hub 4-0:1.0: 2 ports detected
[ 1.934600] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 2.080016] tsc: Refined TSC clocksource calibration: 3058.980 MHz
[ 2.080021] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2c17e97db71, max_idle_ns: 440795314395 ns
[ 2.092477] scsi host4: ata_piix
[ 2.092584] scsi host5: ata_piix
[ 2.092648] ata5: SATA max UDMA/133 cmd 0xfe40 ctl 0xfe50 bmdma 0xfed0 irq 18
[ 2.092651] ata6: SATA max UDMA/133 cmd 0xfe60 ctl 0xfe70 bmdma 0xfed8 irq 18
[ 2.093160] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 2.093167] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 5
[ 2.093173] uhci_hcd 0000:00:1a.2: detected 2 ports
[ 2.093220] uhci_hcd 0000:00:1a.2: irq 22, io base 0x0000fc00
[ 2.093302] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.093303] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.093305] usb usb5: Product: UHCI Host Controller
[ 2.093306] usb usb5: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 2.093308] usb usb5: SerialNumber: 0000:00:1a.2
[ 2.093460] hub 5-0:1.0: USB hub found
[ 2.093468] hub 5-0:1.0: 2 ports detected
[ 2.094060] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 2.094065] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 6
[ 2.094070] uhci_hcd 0000:00:1d.0: detected 2 ports
[ 2.094108] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[ 2.094184] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.094186] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.094187] usb usb6: Product: UHCI Host Controller
[ 2.094189] usb usb6: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 2.094190] usb usb6: SerialNumber: 0000:00:1d.0
[ 2.094332] hub 6-0:1.0: USB hub found
[ 2.094340] hub 6-0:1.0: 2 ports detected
[ 2.094888] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 2.094893] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 7
[ 2.094898] uhci_hcd 0000:00:1d.1: detected 2 ports
[ 2.094938] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[ 2.094988] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.094989] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.094991] usb usb7: Product: UHCI Host Controller
[ 2.094992] usb usb7: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 2.094993] usb usb7: SerialNumber: 0000:00:1d.1
[ 2.095129] hub 7-0:1.0: USB hub found
[ 2.095137] hub 7-0:1.0: 2 ports detected
[ 2.095685] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 2.095692] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 8
[ 2.095697] uhci_hcd 0000:00:1d.2: detected 2 ports
[ 2.095738] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 2.095787] usb usb8: New USB device found, idVendor=1d6b, idProduct=0001
[ 2.095789] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.095790] usb usb8: Product: UHCI Host Controller
[ 2.095792] usb usb8: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[ 2.095793] usb usb8: SerialNumber: 0000:00:1d.2
[ 2.095926] hub 8-0:1.0: USB hub found
[ 2.095933] hub 8-0:1.0: 2 ports detected
[ 2.260035] usb 4-1: new low-speed USB device number 2 using uhci_hcd
[ 2.260048] usb 3-6: new high-speed USB device number 2 using ehci-pci
[ 2.417147] ata5: SATA link down (SStatus 4 SControl 300)
[ 2.417197] ata6: SATA link down (SStatus 0 SControl 300)
[ 2.418689] usb 3-6: New USB device found, idVendor=148f, idProduct=7601
[ 2.418693] usb 3-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.418696] usb 3-6: Product: 802.11 n WLAN
[ 2.418698] usb 3-6: Manufacturer: MediaTek
[ 2.418701] usb 3-6: SerialNumber: 1.0
[ 2.446579] usb 4-1: New USB device found, idVendor=17ef, idProduct=602e
[ 2.446583] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.446586] usb 4-1: Product: USB Optical Mouse
[ 2.446588] usb 4-1: Manufacturer: PixArt
[ 2.450827] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.462892] usbcore: registered new interface driver usbhid
[ 2.462893] usbhid: USB HID core driver
[ 2.463627] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1a.1/usb4/4-1/4-1:1.0/0003:17EF:602E.0001/input/input3
[ 2.463710] hid-generic 0003:17EF:602E.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1a.1-1/input0
[ 2.696085] ata3.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.696097] ata3.01: SATA link down (SStatus 4 SControl 300)
[ 2.700082] ata4.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.700096] ata4.01: SATA link down (SStatus 4 SControl 300)
[ 2.700106] ata4.01: link offline, clearing class 3 to NONE
[ 2.720151] ata4.00: ATAPI: HL-DT-STDVD+/-RW GT30N, A100, max UDMA/100
[ 2.724755] ata4.00: configured for UDMA/100
[ 2.740160] ata3.00: ATA-7: ST3500830AS, 3.AAD, max UDMA/133
[ 2.740163] ata3.00: 976773168 sectors, multi 8: LBA48 NCQ (depth 0/32)
[ 2.815121] ata3.00: configured for UDMA/133
[ 2.815386] scsi 2:0:0:0: Direct-Access ATA ST3500830AS D PQ: 0 ANSI: 5
[ 2.863156] scsi 3:0:0:0: CD-ROM HL-DT-ST DVD+-RW GT30N A100 PQ: 0 ANSI: 5
[ 2.876689] sd 2:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
[ 2.876741] sd 2:0:0:0: [sda] Write Protect is off
[ 2.876743] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.876764] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.891236] sr 3:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.891238] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.891523] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 2.916486] sda: sda1 sda2 < sda5 >
[ 2.916940] sd 2:0:0:0: [sda] Attached SCSI disk
[ 3.104099] clocksource: Switched to clocksource tsc
[ 3.148033] usb 4-2: new low-speed USB device number 3 using uhci_hcd
[ 3.341562] random: fast init done
[ 3.474581] usb 4-2: New USB device found, idVendor=17ef, idProduct=602d
[ 3.474585] usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.474588] usb 4-2: Product: Lenovo Black Silk USB Keyboard
[ 3.474591] usb 4-2: Manufacturer: Lenovo
[ 3.543360] input: Lenovo Lenovo Black Silk USB Keyboard as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.0/0003:17EF:602D.0002/input/input4
[ 3.600351] hid-generic 0003:17EF:602D.0002: input,hidraw1: USB HID v1.11 Keyboard [Lenovo Lenovo Black Silk USB Keyboard] on usb-0000:00:1a.1-2/input0
[ 3.759690] input: Lenovo Lenovo Black Silk USB Keyboard as /devices/pci0000:00/0000:00:1a.1/usb4/4-2/4-2:1.1/0003:17EF:602D.0003/input/input5
[ 3.816115] hid-generic 0003:17EF:602D.0003: input,hidraw2: USB HID v1.11 Device [Lenovo Lenovo Black Silk USB Keyboard] on usb-0000:00:1a.1-2/input1
[ 3.829206] PM: Starting manual resume from disk
[ 3.829210] PM: Hibernation image partition 8:5 present
[ 3.829211] PM: Looking for hibernation image.
[ 3.829382] PM: Image not found (code -22)
[ 3.829385] PM: Hibernation image not present or could not be loaded.
[ 4.252163] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.388735] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.519659] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 5.519796] systemd[1]: Detected architecture x86.
[ 5.535224] systemd[1]: Set hostname to <fadalvmc15>.
[ 6.211466] random: crng init done
[ 6.211469] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.419326] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[ 6.419382] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[ 6.419965] systemd[1]: Listening on udev Kernel Socket.
[ 6.420068] systemd[1]: Listening on Syslog Socket.
[ 6.420120] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.420293] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.420343] systemd[1]: Listening on Journal Socket.
[ 7.031128] lp: driver loaded but no devices found
[ 7.155483] ppdev: user-space parallel port driver
[ 7.173718] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 7.192286] parport_pc 00:02: reported by Plug and Play ACPI
[ 7.192357] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[ 7.288150] lp0: using parport0 (interrupt-driven).
[ 7.573471] systemd-journald[213]: Received request to flush runtime journal from PID 1
[ 8.589035] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input6
[ 8.589041] ACPI: Power Button [VBTN]
[ 8.589127] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input7
[ 8.589129] ACPI: Power Button [PWRF]
[ 8.657324] wmi: Mapper loaded
[ 8.987175] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 8.996505] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000828-0x000000000000082D (\GLBC) (20160831/utaddress-247)
[ 8.996511] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x000000000000082A-0x000000000000082A (\SACT) (20160831/utaddress-247)
[ 8.996515] ACPI Warning: SystemIO range 0x0000000000000828-0x000000000000082F conflicts with OpRegion 0x0000000000000828-0x0000000000000828 (\SSTS) (20160831/utaddress-247)
[ 8.996518] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 8.996521] ACPI Warning: SystemIO range 0x00000000000008B0-0x00000000000008BF conflicts with OpRegion 0x00000000000008B8-0x00000000000008BB (\GIC2) (20160831/utaddress-247)
[ 8.996525] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 8.996526] ACPI Warning: SystemIO range 0x0000000000000880-0x00000000000008AF conflicts with OpRegion 0x000000000000088C-0x000000000000088F (\GIC1) (20160831/utaddress-247)
[ 8.996529] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 8.996562] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 9.045501] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 9.045545] sr 3:0:0:0: Attached scsi generic sg1 type 5
[ 9.143719] [drm] Initialized
[ 9.389586] pci 0000:00:00.0: Intel Q45/Q43 Chipset
[ 9.389610] pci 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[ 9.390174] pci 0000:00:00.0: detected 32768K stolen memory
[ 9.390217] [drm] Memory usable by graphics device = 2048M
[ 9.390220] [drm] Replacing VGA console driver
[ 9.392662] Console: switching to colour dummy device 80x25
[ 9.439199] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 9.439203] [drm] Driver supports precise vblank timestamp query.
[ 9.456377] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 9.463630] [drm] RC6 disabled, disabling runtime PM support
[ 9.465381] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[ 9.633849] fbcon: inteldrmfb (fb0) is primary device
[ 9.663620] snd_hda_codec_analog hdaudioC0D0: autoconfig for AD1984A: line_outs=1 (0x12/0x0/0x0/0x0/0x0) type:line
[ 9.663622] snd_hda_codec_analog hdaudioC0D0: speaker_outs=1 (0x13/0x0/0x0/0x0/0x0)
[ 9.663623] snd_hda_codec_analog hdaudioC0D0: hp_outs=1 (0x11/0x0/0x0/0x0/0x0)
[ 9.663624] snd_hda_codec_analog hdaudioC0D0: mono: mono_out=0x0
[ 9.663625] snd_hda_codec_analog hdaudioC0D0: inputs:
[ 9.663627] snd_hda_codec_analog hdaudioC0D0: Mic=0x14
[ 9.663628] snd_hda_codec_analog hdaudioC0D0: Line=0x15
[ 9.674342] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 9.674586] input: HDA Intel Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 9.674630] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 9.674670] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 9.674714] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input12
[ 9.681416] Console: switching to colour frame buffer device 240x67
[ 9.683811] input: PC Speaker as /devices/platform/pcspkr/input/input13
[ 9.771491] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 9.853602] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 9.925040] iTCO_vendor_support: vendor-support=0
[ 9.925964] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 9.926011] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 9.932096] dell_wmi: Detected Dell WMI interface version 1
[ 9.932172] input: Dell WMI hotkeys as /devices/virtual/input/input14
[ 9.936394] kvm: disabled by bios
[ 9.973391] kvm: disabled by bios
[ 10.370794] intel_powerclamp: No package C-state available
[ 10.400331] intel_powerclamp: No package C-state available
[ 11.396031] usb 3-6: reset high-speed USB device number 2 using ehci-pci
[ 11.407889] Adding 4024316k swap on /dev/sda5. Priority:-1 extents:1 across:4024316k FS
[ 11.546940] mt7601u 3-6:1.0: ASIC revision: 76010001 MAC revision: 76010500
[ 11.588186] mt7601u 3-6:1.0: Warning: unsupported EEPROM version 0d
[ 11.588190] mt7601u 3-6:1.0: EEPROM ver:0d fae:00
[ 11.856426] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 11.856734] usbcore: registered new interface driver mt7601u
[ 18.697521] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.900298] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.951213] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 20.408876] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 20.408985] e1000e 0000:00:19.0 eth0: 10/100 speed: disabling TSO
[ 20.409020] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 137.305945] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 137.429920] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 147.007802] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 148.281706] wlan0: authenticate with c8:3a:35:19:38:b8
[ 148.321526] wlan0: send auth to c8:3a:35:19:38:b8 (try 1/3)
[ 148.323161] wlan0: authenticated
[ 148.324065] wlan0: associate with c8:3a:35:19:38:b8 (try 1/3)
[ 148.327410] wlan0: RX AssocResp from c8:3a:35:19:38:b8 (capab=0x411 status=0 aid=3)
[ 148.371143] wlan0: associated
[ 149.417257] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 217.674185] wlan0: deauthenticating from c8:3a:35:19:38:b8 by local choice (Reason: 3=DEAUTH_LEAVING)
[ 220.286975] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 222.766729] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 224.036520] wlan0: authenticate with c8:3a:35:19:38:b8
[ 224.077556] wlan0: send auth to c8:3a:35:19:38:b8 (try 1/3)
[ 224.079187] wlan0: authenticated
[ 224.080083] wlan0: associate with c8:3a:35:19:38:b8 (try 1/3)
[ 224.085069] wlan0: RX AssocResp from c8:3a:35:19:38:b8 (capab=0x411 status=0 aid=3)
[ 224.116554] wlan0: associated
[ 225.161425] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 971.071315] perf: interrupt took too long (2505 > 2500), lowering kernel.perf_event_max_sample_rate to 79750
What did I do wrong ??
- Thank you received: 5326
24 Oct 2019 20:24 #148741
Replied by PCW on topic Mesa 7i76E - Problem
Look like maybe a LinuxCNC installation issue:
and:
LinuxCNC is not intended to be run as root
and:
The following user(s) said Thank You: Cynas
- Cynas
- Thank you received: 3
24 Oct 2019 20:41 - 24 Oct 2019 20:52 #148745
by Cynas
Thank you
I have not found such information before.
Replied by Cynas on topic Mesa 7i76E - Problem
Thank you
Last edit: 24 Oct 2019 20:52 by Cynas.
- Cynas
24 Oct 2019 20:56 #148750
by Cynas
My other machine for 5i25 / 7i77 mesa works without problems on the administrator account.
24 Oct 2019 21:01 #148751
I dont think the refusal to run as root is card related (at least from the error message)
It might a RTAI vs Userspace LinuxCNC difference
- Thank you received: 7478
24 Oct 2019 22:50 #148762
Replied by tommylight on topic Mesa 7i76E - Problem
Also you have the PC IP set to 1, please change that to 11 or above, gateway has to be 1.
- Cynas
25 Oct 2019 07:15 #148780
by Cynas
I changed PC IP but it did not solve the problem of running on the administrator account.
On another account, LinuxCNC starts correctly.
25 Oct 2019 07:39 #148781
Linuxcnc and a lot of other software on Linux does not work on an administrator account, usually you get a warning that it should not be done at all. Linux has an administrator account just for administrative tasks, almost everything else should be run as a normal user.
Time to create page: 1.703 seconds
