Try to make a prototype mesa 7i92 board
  • Dinuka_Shehan
  • Dinuka_Shehan's Avatar Topic Author
  • Platinum Member
  • Platinum Member
26 Oct 2019 07:38 - 26 Oct 2019 07:41 #148817 by Dinuka_Shehan
Try to make a prototype mesa 7i92 board was created by Dinuka_Shehan
Hi friends,
I am trying to make my own mesa 7i92 prototype board.
Please help me to findout parts list and to make a gerber file for pcb making.
If anyone have a burned or damaged mesa 7i92 board please send me to get data to make a board.
Any ideas???
By
DS
Last edit: 26 Oct 2019 07:41 by Dinuka_Shehan.
26 Oct 2019 12:35 #148825 by tecno
Replied by tecno on topic Try to make a prototype mesa 7i92 board
Why???
Buy a new one = most economical and most certainly fully functional!!!
The following user(s) said Thank You: Mike_Eitel
26 Oct 2019 13:59 - 26 Oct 2019 14:01 #148827 by toplakd
Replied by toplakd on topic Try to make a prototype mesa 7i92 board
Why would you want to make an exact copy of something?
I think it's better to develop own board based on own knowledge and own expectations.
Yes, printing and assembling pcbs in china is very cheap today.
But the board price is not only pcb and assembly, development costs money and thats calculated into endprice.
I suggest you ask PCW, about MESA, he will help you getting further.
Otherwise, if Mesa is too high price, LinuxCNC works well with parallel port cards, and you can get the china BOB on ebay only for the price of pcb and assembly :)
Last edit: 26 Oct 2019 14:01 by toplakd.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
26 Oct 2019 14:07 #148828 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Try to make a prototype mesa 7i92 board
Why can't we make prototype boards for low cost
26 Oct 2019 14:43 #148831 by tecno
Keep dreaming ;)
26 Oct 2019 15:22 #148833 by toplakd
Because you can get the cheap China parallel BOB for 5$ and its working.
If you want MESA, go to their store and buy the card. It's not that expensive compared to other electronics and stuff needed for the CNC.
And if you are making home diy build and looking on every $, than ethernet connection to your machine is the last thing you should worry about.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
26 Oct 2019 15:30 #148835 by Dinuka_Shehan
Anyone have dead mesa boards?
  • Moderator
  • Moderator
26 Oct 2019 16:35 #148840 by tommylight
Replied by tommylight on topic Try to make a prototype mesa 7i92 board
Lets do some math:
Mesa 7i92 = approx.100$
Making one:
Xilinx or whatever chips with the rest, i would guess 300 to 4000$, depending on how many of them you would destroy till you learn about handling electro static sensitive equipment,
Circuit boards = 500 to 1000$ due to errors and mistakes, postage back and forth to china etc,
Other equipment for soldering, several DVM's, oscilloscopes, logic analysers etc.
In total a minimum of 10.000$ till you make the first fully functioning one.
A while back i did make some (2) THC's of my own design and they did end up working very good and extremely fast (10.000 samples per second) that proved a total waste of time and resources as there is absolutely no need for all that speed, costed me over 3000$ for two of them and i am quite good at electronics, hell, even the first prototype worked properly from the first power on.
My advice, buy 2 parallel port cards at 15$ and do some work with it, then when you make some money go visit mesanet.com or mesaus.com or eusurplus.com and be very happy! :)
  • Moderator
  • Moderator
26 Oct 2019 16:36 #148841 by tommylight
Not in my lifetime, i hope ! :)
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
26 Oct 2019 16:55 #148842 by Dinuka_Shehan
Thanks uncle Toma!
You calm down me.
Moderators: PCW, jmelson
Time to create page: 0.434 seconds
