mesa 5i24 with 7i77
20 Nov 2019 04:31 #150717 by nkp
mesa 5i24 with 7i77 was created by nkp
What firmware to use with 5i24 + 7i77 cards ?
How to make a connecting cable ?
20 Nov 2019 04:53 - 20 Nov 2019 04:54 #150719 by PCW
Replied by PCW on topic mesa 5i24 with 7i77
Its not standard (would need custom firmware which I can make if you specify what other I/O you need)
but it can be done. typically you would connect the first 17 I/O bits of one 50 pin
port in the same GPIO order as a Mesa 25 pin FPGA card"
50 PIN      25 PIN
1           1
3          14
5           2
7          15
9           3
11         16
13          4
15         17
17          5
19          6
21          7
23          8
25          9
27         10
29         11
31         12
33         13
and ground pins
50 pin All Even pins
25 pin Pins 18..25
(note Mesa makes a 50 --> 25 pin cable adapter)
Last edit: 20 Nov 2019 04:54 by PCW.
The following user(s) said Thank You: nkp
20 Nov 2019 05:23 #150720 by nkp
Replied by nkp on topic mesa 5i24 with 7i77
what do you mean ?
e.g. :
P2 7i77 ( encoders , DAC)
P3 all IN
P4 all OUT
ps
I have a defective 7i77 card (the bad part of I / O), I want to use with 5i24.
24 Nov 2019 22:51 #151155 by andypugh
Replied by andypugh on topic mesa 5i24 with 7i77
I don't know if this is obvious, but the 7i77 and 5i24 are from different parts of the Mesa offerings.
Mesa started off with the 50-pin bix header cards which are compatible with almost-standard IO cards from the likes of Opto22.
Typically a servo system using one of these boards (5i20, 5i22, 5i23, 5i24) would use the 7i33 daughter card.
Later Mesa noticed that there was an ecosystem based around the parallel port, and brought out the 5i25, which looks like a parallel port but uses an FPGA to do the same things as the p-port, but much faster, but using the same downstream hardware.
Then they brought out their own stepper breakout (7i76) but with a few of the parport lines now handling serial IO to handle a lot more channels than the parport can do.
The 5i24 has 25 IO pins per header, the 5i25 has 17.
This isn't to say that the 7i76 can't work with a 5i24 with the right firmware and a cable adaptor. But it isn't a typical setup, and would require Mesa to make a custom firmware.
30 Nov 2019 19:56 #151601 by PCW
08 Dec 2019 08:49 #152320 by nkp
Both boards were connected (5i24-16 + 7i77).
(on the table)
nkp@nkp-desktop:~$ halrun
halcmd:  loadrt hostmot2
halcmd:  loadrt hm2_pci
halcmd:  loadrt threads
halcmd:  addf hm2_5i24.0.read thread1
halcmd:  addf hm2_5i24.0.write thread1
halcmd:  start
halcmd: show pin
Component Pins:
Owner   Type  Dir         Value  Name
     5  bit   IN          FALSE  hm2_5i24.0.7i77.0.1.analogena
     5  float IN              0  hm2_5i24.0.7i77.0.1.analogout0
     5  float IN              0  hm2_5i24.0.7i77.0.1.analogout1
     5  float IN              0  hm2_5i24.0.7i77.0.1.analogout2
     5  float IN              0  hm2_5i24.0.7i77.0.1.analogout3
     5  float IN              0  hm2_5i24.0.7i77.0.1.analogout4
     5  float IN              0  hm2_5i24.0.7i77.0.1.analogout5
     5  bit   IN          FALSE  hm2_5i24.0.7i77.0.1.spinena
     5  s32   OUT             0  hm2_5i24.0.encoder.00.count
     5  s32   OUT             0  hm2_5i24.0.encoder.00.count-latched
     5  bit   I/O         FALSE  hm2_5i24.0.encoder.00.index-enable
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.00.input-a
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.00.input-b
     5  bit   OUT          TRUE  hm2_5i24.0.encoder.00.input-index
     5  bit   IN          FALSE  hm2_5i24.0.encoder.00.latch-enable
     5  bit   IN          FALSE  hm2_5i24.0.encoder.00.latch-polarity
     5  float OUT             0  hm2_5i24.0.encoder.00.position
     5  float OUT             0  hm2_5i24.0.encoder.00.position-latched
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.00.quad-error
     5  bit   IN          FALSE  hm2_5i24.0.encoder.00.quad-error-enable
     5  s32   OUT             0  hm2_5i24.0.encoder.00.rawcounts
     5  s32   OUT             0  hm2_5i24.0.encoder.00.rawlatch
     5  bit   IN          FALSE  hm2_5i24.0.encoder.00.reset
     5  float OUT             0  hm2_5i24.0.encoder.00.velocity
     5  s32   OUT             0  hm2_5i24.0.encoder.01.count
     5  s32   OUT             0  hm2_5i24.0.encoder.01.count-latched
     5  bit   I/O         FALSE  hm2_5i24.0.encoder.01.index-enable
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.01.input-a
     5  bit   OUT          TRUE  hm2_5i24.0.encoder.01.input-b
     5  bit   OUT          TRUE  hm2_5i24.0.encoder.01.input-index
     5  bit   IN          FALSE  hm2_5i24.0.encoder.01.latch-enable
     5  bit   IN          FALSE  hm2_5i24.0.encoder.01.latch-polarity
     5  float OUT             0  hm2_5i24.0.encoder.01.position
     5  float OUT             0  hm2_5i24.0.encoder.01.position-latched
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.01.quad-error
     5  bit   IN          FALSE  hm2_5i24.0.encoder.01.quad-error-enable
     5  s32   OUT         65535  hm2_5i24.0.encoder.01.rawcounts
     5  s32   OUT         65535  hm2_5i24.0.encoder.01.rawlatch
     5  bit   IN          FALSE  hm2_5i24.0.encoder.01.reset
     5  float OUT             0  hm2_5i24.0.encoder.01.velocity
     5  s32   OUT             0  hm2_5i24.0.encoder.02.count
     5  s32   OUT             0  hm2_5i24.0.encoder.02.count-latched
     5  bit   I/O         FALSE  hm2_5i24.0.encoder.02.index-enable
     5  bit   OUT          TRUE  hm2_5i24.0.encoder.02.input-a
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.02.input-b
     5  bit   OUT          TRUE  hm2_5i24.0.encoder.02.input-index
     5  bit   IN          FALSE  hm2_5i24.0.encoder.02.latch-enable
     5  bit   IN          FALSE  hm2_5i24.0.encoder.02.latch-polarity
     5  float OUT             0  hm2_5i24.0.encoder.02.position
     5  float OUT             0  hm2_5i24.0.encoder.02.position-latched
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.02.quad-error
     5  bit   IN          FALSE  hm2_5i24.0.encoder.02.quad-error-enable
     5  s32   OUT             1  hm2_5i24.0.encoder.02.rawcounts
     5  s32   OUT             1  hm2_5i24.0.encoder.02.rawlatch
     5  bit   IN          FALSE  hm2_5i24.0.encoder.02.reset
     5  float OUT             0  hm2_5i24.0.encoder.02.velocity
     5  s32   OUT             0  hm2_5i24.0.encoder.03.count
     5  s32   OUT             0  hm2_5i24.0.encoder.03.count-latched
     5  bit   I/O         FALSE  hm2_5i24.0.encoder.03.index-enable
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.03.input-a
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.03.input-b
     5  bit   OUT          TRUE  hm2_5i24.0.encoder.03.input-index
     5  bit   IN          FALSE  hm2_5i24.0.encoder.03.latch-enable
     5  bit   IN          FALSE  hm2_5i24.0.encoder.03.latch-polarity
     5  float OUT             0  hm2_5i24.0.encoder.03.position
     5  float OUT             0  hm2_5i24.0.encoder.03.position-latched
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.03.quad-error
     5  bit   IN          FALSE  hm2_5i24.0.encoder.03.quad-error-enable
     5  s32   OUT             0  hm2_5i24.0.encoder.03.rawcounts
     5  s32   OUT             0  hm2_5i24.0.encoder.03.rawlatch
     5  bit   IN          FALSE  hm2_5i24.0.encoder.03.reset
     5  float OUT             0  hm2_5i24.0.encoder.03.velocity
     5  s32   OUT             0  hm2_5i24.0.encoder.04.count
     5  s32   OUT             0  hm2_5i24.0.encoder.04.count-latched
     5  bit   I/O         FALSE  hm2_5i24.0.encoder.04.index-enable
     5  bit   OUT          TRUE  hm2_5i24.0.encoder.04.input-a
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.04.input-b
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.04.input-index
     5  bit   IN          FALSE  hm2_5i24.0.encoder.04.latch-enable
     5  bit   IN          FALSE  hm2_5i24.0.encoder.04.latch-polarity
     5  float OUT             0  hm2_5i24.0.encoder.04.position
     5  float OUT             0  hm2_5i24.0.encoder.04.position-latched
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.04.quad-error
     5  bit   IN          FALSE  hm2_5i24.0.encoder.04.quad-error-enable
     5  s32   OUT             1  hm2_5i24.0.encoder.04.rawcounts
     5  s32   OUT             1  hm2_5i24.0.encoder.04.rawlatch
     5  bit   IN          FALSE  hm2_5i24.0.encoder.04.reset
     5  float OUT             0  hm2_5i24.0.encoder.04.velocity
     5  s32   OUT             0  hm2_5i24.0.encoder.05.count
     5  s32   OUT             0  hm2_5i24.0.encoder.05.count-latched
     5  bit   I/O         FALSE  hm2_5i24.0.encoder.05.index-enable
     5  bit   OUT          TRUE  hm2_5i24.0.encoder.05.input-a
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.05.input-b
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.05.input-index
     5  bit   IN          FALSE  hm2_5i24.0.encoder.05.latch-enable
     5  bit   IN          FALSE  hm2_5i24.0.encoder.05.latch-polarity
     5  float OUT             0  hm2_5i24.0.encoder.05.position
     5  float OUT             0  hm2_5i24.0.encoder.05.position-latched
     5  bit   OUT         FALSE  hm2_5i24.0.encoder.05.quad-error
     5  bit   IN          FALSE  hm2_5i24.0.encoder.05.quad-error-enable
     5  s32   OUT             1  hm2_5i24.0.encoder.05.rawcounts
     5  s32   OUT             1  hm2_5i24.0.encoder.05.rawlatch
     5  bit   IN          FALSE  hm2_5i24.0.encoder.05.reset
     5  float OUT             0  hm2_5i24.0.encoder.05.velocity
     5  u32   IN     0x007F2815  hm2_5i24.0.encoder.muxed-sample-frequency
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.000.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.000.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.000.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.001.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.001.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.001.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.002.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.002.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.002.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.003.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.003.in_not
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.004.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.004.in_not
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.005.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.005.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.005.out
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.006.in
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.006.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.006.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.007.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.007.in_not
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.008.in
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.008.in_not
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.009.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.009.in_not
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.010.in
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.010.in_not
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.011.in
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.011.in_not
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.012.in
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.012.in_not
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.013.in
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.013.in_not
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.014.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.014.in_not
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.015.in
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.015.in_not
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.016.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.016.in_not
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.017.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.017.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.017.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.018.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.018.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.018.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.019.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.019.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.019.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.020.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.020.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.020.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.021.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.021.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.021.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.022.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.022.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.022.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.023.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.023.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.023.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.024.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.024.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.024.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.025.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.025.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.025.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.026.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.026.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.026.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.027.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.027.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.027.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.028.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.028.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.028.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.029.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.029.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.029.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.030.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.030.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.030.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.031.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.031.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.031.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.032.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.032.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.032.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.033.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.033.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.033.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.034.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.034.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.034.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.035.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.035.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.035.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.036.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.036.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.036.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.037.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.037.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.037.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.038.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.038.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.038.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.039.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.039.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.039.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.040.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.040.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.040.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.041.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.041.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.041.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.042.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.042.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.042.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.043.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.043.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.043.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.044.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.044.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.044.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.045.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.045.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.045.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.046.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.046.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.046.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.047.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.047.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.047.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.048.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.048.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.048.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.049.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.049.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.049.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.050.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.050.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.050.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.051.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.051.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.051.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.052.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.052.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.052.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.053.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.053.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.053.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.054.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.054.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.054.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.055.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.055.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.055.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.056.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.056.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.056.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.057.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.057.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.057.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.058.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.058.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.058.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.059.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.059.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.059.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.060.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.060.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.060.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.061.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.061.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.061.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.062.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.062.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.062.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.063.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.063.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.063.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.064.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.064.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.064.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.065.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.065.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.065.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.066.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.066.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.066.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.067.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.067.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.067.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.068.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.068.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.068.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.069.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.069.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.069.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.070.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.070.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.070.out
     5  bit   OUT          TRUE  hm2_5i24.0.gpio.071.in
     5  bit   OUT         FALSE  hm2_5i24.0.gpio.071.in_not
     5  bit   IN          FALSE  hm2_5i24.0.gpio.071.out
     5  bit   IN          FALSE  hm2_5i24.0.led.CR01
     5  bit   IN          FALSE  hm2_5i24.0.led.CR02
     5  s32   OUT         65450  hm2_5i24.0.read.time
     5  s32   OUT             0  hm2_5i24.0.read_gpio.time
     5  u32   OUT    0x00000000  hm2_5i24.0.sserial.port-0.fault-count
     5  u32   OUT    0x00000001  hm2_5i24.0.sserial.port-0.port_state
     5  bit   IN           TRUE  hm2_5i24.0.sserial.port-0.run
     5  bit   I/O         FALSE  hm2_5i24.0.watchdog.has_bit
     5  s32   OUT         12558  hm2_5i24.0.write.time
     5  s32   OUT             0  hm2_5i24.0.write_gpio.time
     7  s32   OUT         65548  thread1.time
09 Dec 2019 16:02 #152371 by nkp
Today installed on the machine.
It works fine.
Mesa_support_excellent !
Moderators: PCW, jmelson
Time to create page: 0.413 seconds
