Magnetic Scale with Mesa 7i76e and 7i85
- CNC_build
20 Nov 2019 11:45 - 20 Nov 2019 11:48 #150741
by CNC_build
Magnetic Scale with Mesa 7i76e and 7i85 was created by CNC_build
Hello all together,
I am currently in the design process of my new CNC Router and am thinking about putting linear scales on it.
It will be run by Mesa 7i76e which I already have on hand, motors are the common JMC 180W servos, minimum Step size is 0,0002mm.
As the 7i76e only has one encoder input I want to extend it with a 7i85.
For the linear scale I'd like to use the following with RS422 signal and 1um resolution:
de.aliexpress.com/item/32962854503.html?...7,searchweb201603_52
Does this sound reasonable or am i taking the wrong approach? Has someone maybe already experience with the ditron magnetic scale?
Thank you in advance,
Robert
Robert
Last edit: 20 Nov 2019 11:48 by CNC_build.
20 Nov 2019 12:42 #150745
How many microns per second will your machine be moving? You just need to be sure that you are below the 7i85 maximum counting rate.
Replied by andypugh on topic Magnetic Scale with Mesa 7i76e and 7i85
- Hakan
- Thank you received: 454
20 Nov 2019 13:35 #150754
by Hakan
Replied by Hakan on topic Magnetic Scale with Mesa 7i76e and 7i85
I have 1 µm linear scales on my milling machine, not ditron though.
The 7i85 can do 20 MHz so if you just keep below 20 m/second you should be safe.
Differential signal is ok. Well, I think this should work just fine.
- CNC_build
20 Nov 2019 14:12 #150757
by CNC_build
Replied by CNC_build on topic Magnetic Scale with Mesa 7i76e and 7i85
Wow, thank you for the fast response. I will give it a try.
- Thank you received: 4149
25 Nov 2019 10:16 #151202
Replied by rodw on topic Magnetic Scale with Mesa 7i76e and 7i85
I'm not helping you here but I used Ditron scales on my manual lathe. I thought they were good quality but I paid a lot less than the listing price back in the day.
Time to create page: 0.612 seconds
