Is there a way to change operation of ENA0 through ENA4 on a MESA 7i77D
21 Dec 2019 01:14 #152979 by jj80909
The original control allowed disabling either or both of the X and Y axis drives for manual use with hand-wheels. The mill also has a standard Bridgeport style manual quill and the whole head assembly is mounted on linear slides for an additional 5" of controlled Z travel.
It's actually fairly useful. For example, disabling X to use it manually but keeping Y enabled to hold position.
I would like to incorporate this function with LinuxCNC and the 7i77D card. From what I've read, the floating enable switches (ENA0 to ENA4) are switched in common. Is there any way to separate them or would you recommend I used some of the unused outputs?
The drives are Yaskawa units and are enabled by a low signal. I did get the 7i77D version with sinking outputs.
Thanks,
Jim
21 Dec 2019 03:46 #152984 by DaOne
The enable just turns on the enable pins and the analog outs. I just leave those enabled and use an IO pin to enable / disable each drive.
07 Jan 2020 21:52 #154262 by andypugh
I think that the enables are separate but tend to be linked to the motion "amp-enable" pins in HAL, which are not separate.
So what you want might be possible with some HAL changes.
Moderators: PCW, jmelson
Time to create page: 0.171 seconds
