Getting more IO with 7i76e or other options?
- simonmn
- Thank you received: 4
22 Dec 2019 13:01 #153027
by simonmn
Getting more IO with 7i76e or other options? was created by simonmn
Hey Guys
I use Mesa 7i76e´s on both my machines, and they are nothing more than amazing.
Although then building a control panel with buttons and lights, the IO on the board quickly runs out.
There are the two 26 pin sockets on the board that seemingly allows for more IO, but I am a little uncertain how this is done.
Are there Mesa IO only board available?
What are the other options?
Thanks in advance
Thanks in advance
- Thank you received: 7478
22 Dec 2019 13:13 #153028
Replied by tommylight on topic Getting more IO with 7i76e or other options?
Check the Mesa 7i73, might be just what you need, it is purpose built for control panels.
The following user(s) said Thank You: simonmn
- bevins
- Thank you received: 338
22 Dec 2019 13:27 #153029
by bevins
Replied by bevins on topic Getting more IO with 7i76e or other options?
Check also the 7i84. 32 inputs 16 outputs.
The following user(s) said Thank You: tommylight, simonmn
- simonmn
22 Dec 2019 14:06 #153030
by simonmn
Replied by simonmn on topic Getting more IO with 7i76e or other options?
I looked a little at the 7i84 some time ago, but couldn't really figure out how it would be connected.
It uses a serial interface... is that the "ethernet" connection on TB3, on the 7i76e?
I'm not too sure how interconnection is handled on mesa product.
- Thank you received: 5326
22 Dec 2019 14:48 - 22 Dec 2019 14:50 #153032
Replied by PCW on topic Getting more IO with 7i76e or other options?
Yes, you would connect a 7I73 or 7I84 to 7I76E TB3 pins 15..20
with a Cat 5/6 network cable terminated with a terminal block on one end
(the 7I76E manual shows how to make such a cable on page 14)
Last edit: 22 Dec 2019 14:50 by PCW.
