7i77 wiring questions
- jeffie-3
29 Dec 2019 22:31 #153518
by jeffie-3
7i77 wiring questions was created by jeffie-3
On one terminal I have TB1 pin 1 GND and TB2 pin 8 GND running to the negative side or the 5 volt supply. Do these need to be seperate? Is ground the same as the negative side of the 5 volt supply?
- bevins
- Thank you received: 338
29 Dec 2019 22:48 #153519
by bevins
I dont know what your asking with that question but......
TB1 pin 1 gets com of 5v power supply and pin 2 gets +5v of power supply.
Replied by bevins on topic 7i77 wiring questions
- jeffie-3
29 Dec 2019 22:56 #153523
by jeffie-3
Replied by jeffie-3 on topic 7i77 wiring questions
Someone else wired my machine. Some things are not working correctly, so I am trying to figure out how to fix it.
The TB1 pin 1 and the TB2 pin 8 has a wire that run to same terminal. On the other side of that terminal has a wire that runs to the negative side of the 5 volt power supply. Is this correct?
- Thank you received: 7478
29 Dec 2019 22:58 #153525
Replied by tommylight on topic 7i77 wiring questions
Answered on the other thread.
The following user(s) said Thank You: jeffie-3
Time to create page: 0.082 seconds
