RS-485 on 5i25+7i76/7i85
- rumking
09 Jan 2020 04:56 #154425
by rumking
RS-485 on 5i25+7i76/7i85 was created by rumking
Hi folks,
is it possible to use RS-485 on 5i25 with 7i76 or 7i85? I am intending to use a mV/V signal convertor which outputs RS-485. (this one: pcm-uk.com/products-services/dcell-embed...ge-digitiser-module/). This should be used for real-time force measurement and the force should be used for motion control (utilizing PID controllers, etc.).
I also came across the 5i21 which has RS-485 interface, but it would be nice to not use 2 PCI cards. From what i was able to gather, it should be possible to use RS-485 on RS-422 interface, but only when 4 wire (full duplex) connection is used. However, the convertor uses 2 wire connection. Is this a problem?
The convertor provides ASCII, MODBUS RTU or MANTRABUS-II protocols. I found that linuxcnc is compatible with MODBUS, but I don't have any experience with it, so I am really confused here.
- Thank you received: 4660
09 Jan 2020 14:25 #154482
Replied by andypugh on topic RS-485 on 5i25+7i76/7i85
With firmware that puts a serial UART on the serial expansion port of the 7i76 you can probably get the data in to HAL, but you would probably need to cobble together a driver.
Sample .comp file here, might be fairly close:
github.com/LinuxCNC/linuxcnc/blob/master...ivers/mesa_uart.comp
- rumking
13 Jan 2020 07:46 - 13 Jan 2020 07:47 #154757
by rumking
Replied by rumking on topic RS-485 on 5i25+7i76/7i85
Andy, thank you for the reply. I created a bitfile with UART on the 7i85 like so:
IOPortTag & x"00" & PktUARTRTag & PktURDataPin, -- I/O 00 PIN 1 PIN 1
IOPortTag & x"00" & PktUARTTTag & PktUTDataPin, -- I/O 01 PIN 14 PIN 2
I got the bitfile generated successfully, but I am afraid this is not possible as the 7i85 has RS422 interface (and I should be using UART on RS485 interface, correct?).
When I --readhmid the 5i25, I get a weird output right where the UARTR/UARTT should be:
1 17 IOPort (unknown-gtag-28) 0 Unknown-Gtag28-Chan0-Pin1 (In)
14 18 IOPort (unknown-gtag-27) 0 Unknown-Gtag27-Chan0-Pin129 (Out)
Does this happen due to broken bitfile? Or is it some mesaflash (using v3.4.0) bug?
Last edit: 13 Jan 2020 07:47 by rumking.
- Thank you received: 5337
13 Jan 2020 07:56 #154758
Replied by PCW on topic RS-485 on 5i25+7i76/7i85
I think Mesaflash does not have the PktUART tag/names yet. I will try and add this is the next few days.
13 Jan 2020 08:24 #154760
It might be simpler to use the plain UART rather than PkTUART.
(or, it might not)
(or, it might not)
13 Jan 2020 08:27 #154761
You might need advice from PCW on the compatibility of RS422 and RS485 physical layers, but I think that they are compatible in the case of Mesa hardware
13 Jan 2020 08:45 - 13 Jan 2020 10:28 #154762
Unfortunately neither the 7I76 nor the 7I85 have RS-485 capable interfaces (no drive enable)
You can fake it pretty well for low speeds by adding series resistance on the
TX outputs before they connect to the RX pair
Mesa 25 pin daughtercards/FPGA cards with 485 capable differential I/O:
7I74, 7I76E (Rev C), 7I77,7I89,7I94,7I95,7I96,7i97,7C80,7C81
Last edit: 13 Jan 2020 10:28 by PCW.
- Thank you received: 4155
13 Jan 2020 11:05 #154772
Replied by rodw on topic RS-485 on 5i25+7i76/7i85
Peter, how do we know what revision of the 7i76e we have?
13 Jan 2020 12:11 #154775
There's a revision letter on the card, but there are no rev C cards in circulation yet (still at assembly)
- rumking
13 Jan 2020 15:26 #154785
by rumking
And what about using a RS422 to RS485 convertor?
Time to create page: 0.165 seconds
