Mesa 7i76e jumper settings
- Clive S
- Thank you received: 486
15 Jan 2020 16:48 #154935
by Clive S
Mesa 7i76e jumper settings was created by Clive S
Peter please can you confirm before I power the 7i76e. Re the jumper setting for W7 and W12
I have received a new board and W7 and W12 are in the up position which is opposite to what the manual says for the default.
I want to power the 7i85s with cable power on P1 So I think they should be up
I purchased these from Eusurplus together so I don't know if they have changed the jumpers from the default.
- Thank you received: 5326
15 Jan 2020 17:44 #154938
Replied by PCW on topic Mesa 7i76e jumper settings
Some cards were sent out with those jumpers "UP"
And yes 'UP" is correct for powering a 7I85S
- Clive S
15 Jan 2020 18:23 #154943
by Clive S
I powered the 7i76e first then checked I had 5v on the correct pins on the ide cable then plugged it in . All fine
Replied by Clive S on topic Mesa 7i76e jumper settings
Time to create page: 0.133 seconds
