configuration and simple test
- Arro
30 Jan 2020 13:59 #156179
by Arro
Replied by Arro on topic configuration and simple test
which wiring were you asking for ?
- Arro
30 Jan 2020 14:53 #156181
by Arro
Little bit fine tuning on LinuxCNC and now it's working great !!
You earned a beer
Thank you
You earned a beer
Thank you
- Arro
30 Jan 2020 16:40 #156186
by Arro
I don't see my last two posts....
anyway it's working fine now, need just a little bit adjustment on the linear moving (LinuxCNC fine tuning)
thanks a lot !!!
thanks a lot !!!
- Arro
07 Feb 2020 14:50 #156700
by Arro
Hi Peter,
how u're doing so far?
I'm back to you for some regulation of PID controller.
Somehow I got the bigger stepper motor running at 600 RPM approx with good results, anyway not repeatable.
PID-settings are : P=1000, I=D=0
I should be able to let run it at 2000 RPM at least
Tried to adjust the P parameter but it's not working well, the only parameter could help me so far is increasing the acceleration value.
If I introduce a D-factor, the movement is much worse !
Any suggestion for the a good direction ?
Cheers
Aronne
Cheers
Aronne
- Thank you received: 5309
07 Feb 2020 15:05 #156701
Replied by PCW on topic configuration and simple test
The PID settings should be:
P= 1/servo period (1000 for standard 1000000 ns = 1ms servo thread period)
FF1 = 1.000
Everything else 0
These settings are not really something you "tune"
If you used pncconf to set this up those values should already be correct
What actual problem do you have and can you post your current hal and ini files?
FF1 = 1.000
Everything else 0
Time to create page: 0.179 seconds
