EtherCAT from Mesa?
- Moronicsmurf
28 Feb 2020 20:58 #158787
by Moronicsmurf
EtherCAT from Mesa? was created by Moronicsmurf
Guessing this is a question for PCW.. Is there any plan on making a EtherCAT master board in the same FPGA manner we are so much loving, but that can talk to an EtherCAT bus??
Mainly cuz there is alot of cheap ethercat servo drivers available on the market now both from china and as "spares" from european manufacturers. But seems to be a bit clunky to get working with LCNC atm.
- Thank you received: 5329
28 Feb 2020 21:15 #158789
Replied by PCW on topic EtherCAT from Mesa?
I've considered it and even made a prototype card (7I62) a number of years ago, but its not something I have a great deal of interest in currently.
- Moronicsmurf
28 Feb 2020 21:18 #158790
by Moronicsmurf
Replied by Moronicsmurf on topic EtherCAT from Mesa?
Ah sorry to hear.
Seems like the future to me for servo based solutions at least.
28 Feb 2020 21:28 #158791
Yes, its going to be a common choice for newer high end systems, but those systems typically dont need FPGA flexible I/O, since all required I/O is built into the drives...
- Moronicsmurf
28 Feb 2020 23:31 #158792
by Moronicsmurf
You are prob right. But i would think the flexible IO would come in handy for other things tho, toolchangers, quadrature encoders and so on when you wanna convert an old Machine into these cheap chinese drives or even the Pronet ones that is quite affordable..
Wouldnt look at em as a high end system solution more as a "easy way of wiring" kind of solution.. Only hard part i have issues with finding is that first inerface the ethercat master.
- Moronicsmurf
02 Mar 2020 10:58 #158960
by Moronicsmurf
So would there be any chance i could get my hands on the code for the prototype board you made?
I had a realization that ethercat for lcnc in its current state wouldnt have any hardware step generators or pwm signal generators, and to be honest that would be the biggest benefit of having a hostmot2 card as a ethercat master rather than the flexible IO part.. Even if the ethercat bus itself would be the flexible IO down the line.
- linuxcnc4less
14 Oct 2024 06:40 #312032
by linuxcnc4less
Replied by linuxcnc4less on topic EtherCAT from Mesa?
The following user(s) said Thank You: Beovoxo
