Unexpected realtime delay error on new Mesa 7i96 install
- GND
20 Mar 2020 21:28 #160948
by GND
Replied by GND on topic Unexpected realtime delay error on new Mesa 7i96 install
Apologies and correction - the red "INIT" LED (CR11) becomes lit on the error. The yellow "PWR" LED is always lit! (I was not in the shop when I wrote that last email. Now logged into the forum on my Linux machine next to the board.....).
- Thank you received: 5330
20 Mar 2020 23:27 #160958
Replied by PCW on topic Unexpected realtime delay error on new Mesa 7i96 install
A solid red init LED means a watchdog bite, which likely means the the host
PC has decided to wander off and do something else for a fair number of
milliseconds. It might be a hardware issue (Ive seen this happen with failing
hard drives) or just some power management option that cannot be turned off
The following user(s) said Thank You: GND
- GND
20 Mar 2020 23:45 #160960
by GND
OK, sounds serious. I had the watchdog set for 50ms, and just set it for 500ms as a test. It still lights the red LED on starting LinuxCNC. It's a brand new SSD, so is this looking like I am flogging a dead horse...?
21 Mar 2020 02:25 #160961
It doesn't sound good, maybe that PC is just not suited to real time
Does dmesg show any Ethernet link up/down messages?
that's another possible cause of losing communications...
- bbsr_5a
- Thank you received: 106
21 Mar 2020 12:12 #160981
by bbsr_5a
Replied by bbsr_5a on topic Unexpected realtime delay error on new Mesa 7i96 install
can you tell us what pc this is
what Linux you are running
Did you hidde the othere processors if it has more so it runs only on one with the realtime kernel ISOCPU
very rear to get this numbers so hard
there are 50USD pc that get it down to <5k
- Thank you received: 7488
21 Mar 2020 12:43 #160983
Asus EEE, if you google that you will find it is an old very small 7" laptop, at least the first series was, i had 2 of them.
Replied by tommylight on topic Unexpected realtime delay error on new Mesa 7i96 install
He said that on the first post:can you tell us what pc this is
- bbsr_5a
21 Mar 2020 16:00 #160990
by bbsr_5a
@ tom what latency you got on this or did you only use them as WIN desk
21 Mar 2020 16:52 #160991
They could do over 4 hours on batteries at that time, so they had weak processors, slow memory, to much power saving, etc. They will most probably not do for Linuxcnc.
I had 2 of them when they got out, the first series of them. They were underwhelming so i sold them promptly, and had to install winxp on one of them for the client.@ tom what latency you got on this or did you only use them as WIN desk
- GND
21 Mar 2020 17:00 #160996
by GND
I just tried dmesg as suggested - I'm only a Linux beginner, so didn't know what to expect. But I think this may be helpful.
Before invoking LinuxCNC, it had a mix of various messages about the system. I fired up LinuxCNC, and let it go it its error state - and then retried dmesg. I got literally screenfulls of "UDP Checksum error", which sound extremely suspicious!
FWIW, I closed LinuxCNC, power cycled the 7i96, and pinged it. It worked OK, with the usual 0.3ms ping time. I tried dmesg again, but just saw mention of the link being lost and regained - due to the power cycle. So it was definitely running LinuxCNC that provoked the errors.
Any idea on what could be causing that?
- GND
21 Mar 2020 17:06 #160999
by GND
Ref my PC....
They are probably what you had, Tom, but maybe in a slightly different format. They are super small form factor desktops rather than laptops, and based on an Intel Atom N270. This is a 1.8GHz single core processor of 2008 vintage. I agree that they are likely not up to the task in hand here - but they would have been brilliant if they had been, as they are extremely neat!
Funny how they are tantalisingly close though. OK, so the ping times are poor, but from what has been said the latency figures seem workable if not ideal. Even if I could have tested my motors it would have been nice, but I'm coming round to the fact that I should probably just give up on them, and move on.....
Time to create page: 0.120 seconds
