Mesa 7i76e Broken ? How to tell
- bbsr_5a
- Thank you received: 106
25 Mar 2020 11:57 #161420
by bbsr_5a
Mesa 7i76e Broken ? How to tell was created by bbsr_5a
Hi
i receved a call on how to check if the Card is ok on powerup
the card is not responding
acording to the Manual its not clear as of language understanding if the CR2 /DONE
State is the LED that tells
it is inverted i guess it is only RED LED not duo red/green so if it is ON the 7i76e is broken
cycling the Reset Jumper during 5sec powerup dident work also
((Fallback W9 Cycle))
is this correct ?
is this correct ?
- Thank you received: 5334
25 Mar 2020 14:17 #161433
Replied by PCW on topic Mesa 7i76e Broken ? How to tell
If the red /done LED stays on after a power cycle, the card was not able to configure
the FPGA. Is the /INIT LED illuminated?, is the Yellow PWR LED CR13 illuminated
- bbsr_5a
26 Mar 2020 09:35 #161548
by bbsr_5a
Replied by bbsr_5a on topic Mesa 7i76e Broken ? How to tell
thank you for the info i will try< to get the part to homeoffice
hard to go to shop as police/GOV/FireBrigate/ patrols the street
metall shops need to be closed in Germany
Time to create page: 0.271 seconds
