7i76 repair?
- VVO
14 Apr 2020 12:23 #163968
by VVO
7i76 repair? was created by VVO
Hi
Unfortunately, i think, today i accidentaly killed my 7i76, during debug cnc machine cabinet.
And it was last one
+24V slided down to board and touched +5V bus.
As result - short circiut inside dsPIC (i found that, desoldering Vdd pins on ICs)
So question is - if i replace this dsPIC with new, can i flash it with PICkit2?
Is there avaliable binaries to do that?
I have tight deadline to run this machine, and looking any variants to run it ASAP
Of course, i looked to mesanet store at once, but these boards signed as out of stock
Knowing how long can be shipping to Russia plus terms when they became avaliable, frustrate me.
- Thank you received: 7506
14 Apr 2020 12:51 #163971
Replied by tommylight on topic 7i76 repair?
Try
eusurplus.com
it's in Portugal so might be faster, or not.
eusurplus.com
- Thank you received: 5337
14 Apr 2020 13:11 #163972
Replied by PCW on topic 7i76 repair?
You should be able to flash the DSPIC with PICkit2, though if you got 24V on the 5V rail I would expect more widespread damage (the DSPIC is not on the 5V rail. its powered by 3.3V derived from the field power, so if 24V shorted to the 3.3V rail more 3.3V chips may have been damaged)
freeby.mesanet.com/7I76S14H1.HEX
Is the DSPIC firmware for the 7I76
- VVO
14 Apr 2020 13:33 #163975
by VVO
Replied by VVO on topic 7i76 repair?
Same problem, 7i76 out of stock on site.
- strahlensauger
- Thank you received: 66
14 Apr 2020 15:31 #163978
by strahlensauger
Replied by strahlensauger on topic 7i76 repair?
- VVO
14 Apr 2020 16:01 #163979
by VVO
Thanks a lot!
Seems i confused with 5V and 3.3V. It should be 3.3V supply.
Now trying to buy proper dsPICs in local store, but i find that they relative exotic in this part of world)
Is dsPIC33FJ16GS402 replaceable with dsPIC33FJ16GS502?
Store says that 502 will shipped much faster.
14 Apr 2020 16:13 #163982
Possible but not too likely.
Other options are:
Get a 7I76E (connector compatible with 7I76)
We could mail you a dsPIC33FJ16GS402
(it fits in an envelope, no idea how long it would take though)
Add a 7I84 (has same field I/O as 7I76 except no analog spindle)
Unfortunately we have had large delays on some cards due to the virus
but we expect to get 7I76's next week sometime
Other options are:
- Mike_Eitel
- Thank you received: 183
14 Apr 2020 16:30 - 14 Apr 2020 16:33 #163983
by Mike_Eitel
Replied by Mike_Eitel on topic 7i76 repair?
Sorry to say, but i would be carefull with the austrian. Make sure that he can realy deliver. To my best knowledge I was not the only one who had not the best experience.
On the other side i will only speak positive about eurosurplus. Good and fast.
m5c
m5c
Last edit: 14 Apr 2020 16:33 by Mike_Eitel.
14 Apr 2020 18:28 #163991
I got almost all my Mesa boards from them, they are very good and very fast.On the other side i will only speak positive about eurosurplus. Good and fast.
14 Apr 2020 20:54 #164001
We just got some 7I76s in so they are available from Mesa
Time to create page: 0.228 seconds
