Power supply selection for stepper based config
- alkabal
- Thank you received: 52
15 Apr 2020 20:38 - 15 Apr 2020 20:40 #164083
by alkabal
Power supply selection for stepper based config was created by alkabal
Hi
Can you help for choose the good power supply, i'm unfortunately really unsure and i like to select the most appropriate option for a correct price.
This is for a little mill Meccanica Cortini L300 retrofit with :
3x nema 34SSM9460-EC1000 121 mm 7.5nm 6A closed loop
3x hsb86h (not delivered) 20-63VAC or 30-90VDC
original screw without ball (like to be replaced but i'im really affraid fro manufacturer selection and or price)
Planned a 4th axis with similar motor
Liked a ATC stepper based
Well i have some difficulty for decision,
it is better to have all separated supply ?
one for all ?
one for XYZ stepper but another for additional stepper ?
I think this is better to use toroidal transformer + diode bridge + capa V/S chinese regulated power supply.
Br
one for all ?
Br
Last edit: 15 Apr 2020 20:40 by alkabal.
- Thank you received: 7488
15 Apr 2020 23:44 #164095
Replied by tommylight on topic Power supply selection for stepper based config
If you use a toroidal transformer there is no need for rectifiers and capacitors, they are built into the drives, as stated by the 20-63VAC.
If you go the SMPS way, i would not go over 60VDC for those drives, and anything above 15A should be more than enough even when you add the 4'th axis.
- BeagleBrainz
- Visitor
16 Apr 2020 00:27 #164100
by BeagleBrainz
Replied by BeagleBrainz on topic Power supply selection for stepper based config
If you go for a SMPS don't go for the cheap Chinese devices.
Go for a name brand one, such as Meanwell (I'm not pushing this particular brand), I use multiple ones in my system, one 48v for steppers and one 12v & 2 5v for field & logic, never had an issue, even in the height of an Aussie summer. With a name brand device you can be assured it has gone thru the approvals for your country. The Chinese ones have been know to rely on the importer to arrange for the approvals....which many ebay sellers don't bother with.
Yeah I know others will disagree, but I've worked around power & electronics long enough not to take shortcuts.
Oh and don't take electrical advice from randoms on the internet. That even includes myself.
- alkabal
16 Apr 2020 02:13 - 16 Apr 2020 02:18 #164102
by alkabal
Replied by alkabal on topic Power supply selection for stepper based config
Hi
many thanks for both reply
@ tommylight
you are right i have missed these driver accept alternative power one good point for save space inside box !
I have calculated something like 20A is perfect with something like 48v for toroidal so i'm happy for your confirmation.
at comparable price it is better to have 4x5A or 1x20A ?
@ BeagleBrainz
Good to know you are happy with branded SMPS, i don't really know why but i like more the toroidal solution mostly regarding to fiability vs cheap SMPS. (but i will check for branded unit)
@ tommylight
@ BeagleBrainz
Last edit: 16 Apr 2020 02:18 by alkabal.
- BeagleBrainz
- Visitor
16 Apr 2020 02:50 #164105
by BeagleBrainz
Linear maybe a better solution in your case 20A would do for all 4 axis
www.geckodrive.com/support/step-motor-ba...r-supply-basics.html
16 Apr 2020 09:39 #164125
Keep in mind, all those were 12V supplies for driving LED strips, 200 and 400W rated.
Did some tests a while back for one of the big importers here on those Chinese SMPS power supplies, the results were pitiful, most of them could do around 30 to 40% of the rated power before they would heat up way to much to be reliable, and they skimp on filtering parts a lot. Only one manufacturer had consistently sustained over 60% of rated power without issues, i can look for the brand name, but they do not sell on eBay or aliexpress.The Chinese ones have been know to rely on the importer to arrange for the approvals....which many ebay sellers don't bother with.
- Thank you received: 4150
16 Apr 2020 10:07 #164128
Replied by rodw on topic Power supply selection for stepper based config
[quote="tommylight" post=164125 Only one manufacturer had consistently sustained over 60% of rated power without issues, i can look for the brand name, but they do not sell on eBay or aliexpress.
[/quote]
Whats this? A Pork chop ?
www.aliexpress.com/item/32951223637.html...02_,searchweb201603_
350 W granted I know
[/quote]
16 Apr 2020 11:54 #164132
i tested 5 manufacturers, they are all new and have nothing on ebay or any other site.
?????????Whats this? A Pork chop ?
- alkabal
16 Apr 2020 15:09 #164152
by alkabal
fr.rs-online.com/web/p/transformateurs-toriques/1234006/
or
www.mouser.fr/ProductDetail/Triad-Magnet...%252BuZJXNhMAvK8c%3D
as i can see SMPS from Meanwell is more expensive with comparable spec.
or
16 Apr 2020 15:16 #164153
The mouser one is cheaper and much heavier ??? Strange.
Get one with a single output.
Time to create page: 0.134 seconds
