6i25/7i76 TB3 Encoder Jumper Settings - mixed mode possible?
- Joco
- Thank you received: 327
17 Apr 2020 17:19 #164344
by Joco
6i25/7i76 TB3 Encoder Jumper Settings - mixed mode possible? was created by Joco
I understand there are 3 jumpers on the 7i76 board that switch the encoder inputs from differential to single (TTL) mode. What I would like to know is can I do a mixed model?
Have the A and B legs differential coming from an encoder on the motor but have the index as single/TTL coming off a sensor (proximity or hall effect) that is directly on the spindle. This setup being to remove issues with variation in gearing between motor speed and spindle speed. I can use scaling for the speed side of things but from what I have read having an accurate index trigger on the actual spindle gives better co-ordinate movement.
So if yes, what jumper is tied to what leg?
Thanks,
James.
W4 --> ?
W5 --> ?
W6 --> ?Thanks,
James.
- Thank you received: 5337
17 Apr 2020 17:24 - 17 Apr 2020 17:24 #164347
Replied by PCW on topic 6i25/7i76 TB3 Encoder Jumper Settings - mixed mode possible?
Yes, each channel can be set individually.
The jumpers are arranged in the same order as the encoder connector:
W4 IDX mode
W5 B mode
W6 A mode
W4 IDX mode
W5 B mode
W6 A mode
Last edit: 17 Apr 2020 17:24 by PCW.
The following user(s) said Thank You: Joco
Time to create page: 0.071 seconds
