Stepper Drive Enable Circuit
  • Project_Hopeless
  • Project_Hopeless's Avatar Topic Author
  • Elite Member
  • Elite Member
18 Apr 2020 17:29 #164477 by Project_Hopeless
Stepper Drive Enable Circuit was created by Project_Hopeless
I have a Mesa 7i96e and some inexpensive Chinese stepper drives. To disable the drive you set the "Enable" input high 5V.
Should I use the E-Stop-out from the 7i96 to set the enable high or simply loop back through the physical E-Stop button N/O contact to provide the 5V?
19 Apr 2020 11:45 #164626 by bbsr_5a
Replied by bbsr_5a on topic Stepper Drive Enable Circuit
this depends on you
I personly use the MACHINE ON F2 for the Drives to be enabled and i also use a Realy to get the 5V to ENA or break the circuit non closed as then it can also be to a Simple externel button
Why not E-stop estop is for be a emergency so close everything full power off
and in Normal use you only need to get the Power from the Drives for small adjust or simple time to get somthing done
so no need to close all down
  • Project_Hopeless
  • Elite Member
  • Elite Member
19 Apr 2020 14:33 #164642 by Project_Hopeless
Replied by Project_Hopeless on topic Stepper Drive Enable Circuit
With the negative logic on these inexpensive drives it's not a fail safe condition. A wire break will not be detected.
If an e-stop is initiated do all Mesa I/O go low or do they still function normally.
19 Apr 2020 19:00 #164663 by PCW
Replied by PCW on topic Stepper Drive Enable Circuit
E-Stop behaviour is entirely determined by your external wiring and
hal setup. That is, there in no default hardware I/O connection to
E-Stop unless its setup in the hal file
Start-up state and state after shutdown/host crash of Mesa cards
is predictable (for example the SSRs on a 7i96 will all be off at power up
or LinuxCNC shutdown or say loss of communication with the host)
  • Project_Hopeless
  • Elite Member
  • Elite Member
20 Apr 2020 20:53 #164888 by Project_Hopeless
I understand now. That's what I was getting at, the I/O state after an abnormal event including E-Stop.
I guess I could add an ice-cube relay to invert the drive enable Eh! maybe I'll just leave it enabled all the time :huh:
20 Apr 2020 21:07 #164890 by PCW
Not sure what the drive enable gets you with a step drive
In fact a step motor may stop faster enabled than disabled
when the pulse stream stops (as would happen with and Estop or watchdog bite)
Moderators: PCW, jmelson
Time to create page: 0.109 seconds
