Error finishing read mesa 7i96
- Clive S
- Thank you received: 486
27 Apr 2020 09:53 #165773
by Clive S
Error finishing read mesa 7i96 was created by Clive S
What would cause this. Generally happens once at the start of a session .
hm2/hm2.7i96.0: error finishing read
- bbsr_5a
- Thank you received: 106
27 Apr 2020 11:09 #165796
by bbsr_5a
Replied by bbsr_5a on topic Error finishing read mesa 7i96
is there a dauthercard in the Flashfile and itt is not present in the hardware
make a readback of the pins
- Thank you received: 7488
27 Apr 2020 12:04 #165810
Replied by tommylight on topic Error finishing read mesa 7i96
That is usually a bad or not sufficient 5V supply or ethernet or even bad latency fluctuations.
The following user(s) said Thank You: Vector
- Thank you received: 5330
27 Apr 2020 14:06 #165822
Replied by PCW on topic Error finishing read mesa 7i96
I would run the card for a while and then check the tmax values
As tommylight said, bad latency can cause dropped packets, leading to that error
To get the tmax values, run
halcmd show param *.tmax
and paste the values here
(your CPU speed is also needed since these numbers are all in CPU clocks)
The following user(s) said Thank You: tommylight, Clive S
- Clive S
27 Apr 2020 14:33 - 27 Apr 2020 14:37 #165831
by Clive S
Replied by Clive S on topic Error finishing read mesa 7i96
Peter to be clear this only happens on LinuxCNC startup and the mill performs ok after that.
Also how do I get the cpu speed. The mill is about 25 miles away but can get the guy to run a terminal and send them to me.
To answer Tom. Yes I put a good 5V power source in when I did the control box.
Last edit: 27 Apr 2020 14:37 by Clive S.
27 Apr 2020 14:36 #165832
It still indicates a lost packet which is most likely due to a latency issue
Time to create page: 0.092 seconds
