Mesa 7i73 wiring question
- Thank you received: 4150
01 May 2020 09:49 #166295
Mesa 7i73 wiring question was created by rodw
If you were using say a Mesa 7i76e, with a PC built into a remote console, would it be possible to run the smart serial RS422 on the unused pairs on the ethernet cable from the 7i76e and split them out at the PC side to a 7i73 powered from 5 volts stolen from a USB port?
It means there is no GND signal.
It would be a real neat trick if it could be done.
- Thank you received: 7488
01 May 2020 10:14 - 01 May 2020 10:15 #166298
Replied by tommylight on topic Mesa 7i73 wiring question
Ethernet uses 4 wires, Mesa 7i73 need 6 for power, gnd, two TX and two RX.
Only 8 wires in the CAT5 or 6.
But you could power it from another source and use the shielding fro GND.
Last edit: 01 May 2020 10:15 by tommylight. Reason: info
01 May 2020 10:25 #166299
Replied by rodw on topic Mesa 7i73 wiring question
Yeh, you should be able to steal power from USB. So just use the shield for GND then?
01 May 2020 10:58 - 01 May 2020 10:59 #166301
And use the same pair for Tx and the other pair for RX.
Yes.Yeh, you should be able to steal power from USB. So just use the shield for GND then?
Last edit: 01 May 2020 10:59 by tommylight. Reason: info
- Mike_Eitel
- Thank you received: 183
01 May 2020 14:01 #166319
by Mike_Eitel
Replied by Mike_Eitel on topic Mesa 7i73 wiring question
Be very carefull. I had a f.. problem getting a high voltage/current short circit over the 7i73 gnd down in the 7i76e... grilling both of them.
Floating grounds is never good. Connect with hem at least via resistor, paralleled by low inductive capacitor.
Time to create page: 0.127 seconds
