Stepping up driver ouput voltage
23 May 2020 02:29 #168630 by An
Hi all, I purchased an sanyo denki stepper motor and thought that the inductance was 1.6mh, turns out it was 16... I am running gecko G540 and I dont have enough voltage. Is it possible to up the voltage coming out of the driver or is this a bad idea?
Ant
23 May 2020 02:32 #168632 by PCW
Replied by PCW on topic Stepping up driver ouput voltage
No, the best you can do is run the G540 at close to its limits (48V?)
16 mH is really high so unlikely to work well with most common step drives
23 May 2020 23:21 #168742 by An
Replied by An on topic Stepping up driver ouput voltage
Ok, thanks PCW
Moderators: PCW, jmelson
