Mesa RPI4 Ethernet vs GPIO?
- broose_goose
28 May 2020 04:57 #169190
by broose_goose
Mesa RPI4 Ethernet vs GPIO? was created by broose_goose
Any pros / cons for using a mesa Ethernet board like the 7I96 vs using the 7C81 with a 7I78 for a Raspberry Pi? Tried reading around and couldn't find any comparisons, only "not to use a switch" if going the Ethernet route...
- BeagleBrainz
- Visitor
28 May 2020 05:07 #169191
by BeagleBrainz
Replied by BeagleBrainz on topic Mesa RPI4 Ethernet vs GPIO?
The ethernet boards are easily transferred to another platform, with the RPi specific boards you are limited to the RPi. Something to think about for the future.
The ethernet boards can be put in a cabinet\enclosure separate from RPi or PC.
These are just my thoughts.
- bbsr_5a
- Thank you received: 106
28 May 2020 05:39 #169193
by bbsr_5a
Replied by bbsr_5a on topic Mesa RPI4 Ethernet vs GPIO?
you shoudt consider the slightly higher cost on mini-Atx but gives you so mutch advantige on use
- broose_goose
28 May 2020 05:47 #169195
by broose_goose
Replied by broose_goose on topic Mesa RPI4 Ethernet vs GPIO?
Platform agnostic is a good point... wouldn't have thought about that, so thank you!
The pi is used mainly as an interface, like octoprint for a reprap printer, so I don't think the mini-atx would give me much benefit
- BeagleBrainz
- Visitor
28 May 2020 06:15 #169197
by BeagleBrainz
You understand that Linuxcnc still calculates all the motion control, regardless of what board you use. The MESA boards do the timing but not the GCode interpretation. So no the RPi would not be used mainly as an interface,it's an integral part of Linuxcnc.
I hope you weren't under the assumption that Linuxcnc is a glorified gcode sender, similar to gerbl ? The PC or SBC that runs Linuxcnc is the CNC controller.
You would gain benefit from a modern x86 platform, greater amount of memory, ability to use a SSD closer to it's native speed with a SATA interface rather than USB3 to SATA.
Time to create page: 0.237 seconds
