THCAD 10 / 7i76 wiring
- luftlupus
- Thank you received: 16
14 Jun 2020 23:08 #171655
by luftlupus
THCAD 10 / 7i76 wiring was created by luftlupus
- Thank you received: 5334
14 Jun 2020 23:32 - 14 Jun 2020 23:33 #171657
Replied by PCW on topic THCAD 10 / 7i76 wiring
1. The THCAD 5V power should come from 7I76 TB3 pins 6 and 9
2. Normally "START" requires a contact closure.
This can be done by using the spindle enable pins
(TB4 pins 5 and 6)
You will need to determine the polarity of the "START"
signals with a voltmeter before wiring
(TB4 pins 5 and 6)
Last edit: 14 Jun 2020 23:33 by PCW.
The following user(s) said Thank You: luftlupus
- luftlupus
16 Jun 2020 01:24 #171800
by luftlupus
Replied by luftlupus on topic THCAD 10 / 7i76 wiring
16 Jun 2020 02:05 #171808
Continuity is not really meaningful if there is a voltage present.
Yes
So i tested the start pins and got 5v positive on pin 4 and negative on pin 3, also did continuity but the positive and negative reverse directions? not a huge expert on that.
I would assume that this being the case i would wire pin 3 start to "TB4 pin 5" and then pin 4 start to "TB4 pin 6" ?
Yes
- luftlupus
17 Jun 2020 07:50 #171896
by luftlupus
- Thank you received: 4152
17 Jun 2020 09:02 #171897
Replied by rodw on topic THCAD 10 / 7i76 wiring
I'm just a bit confused about the + 12 v power supply on pin 12. Is that what you are using for 7i76e field power? To me this should be connected to field power +24v. There is no need for an extra power supply.
Also I would suggest that you connect a 1K 1W resistor to your ArcOK input to Field power ground -24V
This will ensure that sufficient current passes through the internal relay in the plasma cutter so the current draw exceeds the minimum required current so the contacts don't oxidise and cause intermittent behaviour. I got caught with this with my Everlast and still do it the same way on my Thermal Dynamics. It could save many hours of frustration.
- luftlupus
17 Jun 2020 23:25 - 17 Jun 2020 23:30 #171935
by luftlupus
Last edit: 17 Jun 2020 23:30 by luftlupus.
18 Jun 2020 00:04 #171939
Yes, you might need to revisit the resistor value as its specced for 24v field power. It probably needs to cause say 100 mA current to flow and be rated to handle the power (in watts).
Normally, we would use 24 v field power which would give better noise immunity (eg a lot more noise required to alter the signal). $40 for say a Meanwell 2 amp power supply is not really significant.
- luftlupus
18 Jun 2020 00:09 #171940
by luftlupus
Thanks for the advise, i will change the field power to 24v and add in the resistor.
- asuratman
11 Apr 2021 03:59 #205600
by asuratman
Replied by asuratman on topic THCAD 10 / 7i76 wiring
Hello,
Can you show me which one the voltage div and arc ok on chinese plasma cutter has pilot arc (such as tosense plasma cut50 : www.aliexpress.com/item/4001168150005.ht...02_,searchweb201603_) ?
Time to create page: 0.367 seconds
