7I90 spi vs ethernet cards
- blazini36
- Thank you received: 167
26 Jun 2020 19:19 #172813
by blazini36
7I90 spi vs ethernet cards was created by blazini36
Trying to figure out a couple things here. I'm thinking about using the 7i90 as sort of a swiss army knife and pumping a new bitfile into it for specific hardware attached to it when necessary.
I haven't messed with any of the SPI cards yet, only the ethernet cards. I have some projects I want to get going with some ARM boards (yeah I know) and I don't like tying up the single ethernet port, almost everything including some x86 SBCs have an SPI interface on the GPIO that's otherwise not doing anything.
So the question is, what is the performance difference between the ethernet interface and the SPI interface and is it major? In the case of using a raspberry pi, I would assume that the hm2_rpspi hal driver will work with a 7i90 as well but in the case that it's not a raspberry pi, how much of a performance difference should I expect using hm2_spi over hm2_rpspi and how much of a PIA is it to get spi anything working on a random ARM SBC?
- Thank you received: 5335
26 Jun 2020 22:03 #172820
Replied by PCW on topic 7I90 spi vs ethernet cards
The main issue with the generic spi driver (hm2_spi) is that it uses the
OS SPI device. Unfortunately these often have poor real time characteristics
so its hit-or-miss if the SPI driver for particular hardware will be usable or not...
( that's one of the the reasons for the hardware specific hm2_rpspi driver)
- blazini36
27 Jun 2020 03:50 #172832
by blazini36
Replied by blazini36 on topic 7I90 spi vs ethernet cards
Well best case scenario, what does the hm2_rpspi driver look like against hm2_eth and does it work with the 7i90?
27 Jun 2020 15:44 #172861
Probably a bit slower, And yes it will work with the 7I90
- blazini36
28 Jun 2020 05:07 #172951
by blazini36
Is there any source or description for the specific bitfiles for the 7i90? There are plenty of bitfiles in the zip but I only see 1 source pinfile that is setup as generic gpio on all pins. Is there any way to find out how the compiled bitfiles have the pins arranged?
28 Jun 2020 14:32 #172995
Any of the 72 pin pinout source files can be used with the 7i90
Typically the bitfiles have a similar name to the pinout source file
You can also read out the pin connections with mesaflash
Time to create page: 0.416 seconds
